Old 04-13-2016, 02:50 PM   #1
V-10 Tuner
Has anyone tried the 5 star V-10 Tuner?
inks is offline   Reply With Quote
Old 04-15-2016, 09:54 AM   #2
LLVanB's Avatar
I installed 3 years ago and wouldn't be without it. An amazing improvement in drivability! Highly recommend it!!!
LLVanB
2013 Coachmen Encounter 36KS, 2012 Honda CR-V toad, Roadmaster Falcon 2, Brake Buddy Vantage Select, Protect-a-Tow, 5 Star Tune, M4 LED lights and many other accessories & mods.
LLVanB is online now   Reply With Quote
Old 04-19-2016, 08:40 AM   #3
pashooter's Avatar
Installed it in my Pursuit last Fall. Only have a couple hundred miles behind the wheel since then but even so I can say it's made a world of difference. My biggest gripe in the stock configuration was the tendency to drop directly into 3rd gear on even slight inclines while on the highway. Now it gracefully descends through the gears only as needed. On a recent 85 mile Interstate ride home from the dealer (where I was having warranty work performed) it only made it down to 3rd once, and that was on a prolonged hill climb with the cruise engaged.
The cabin noise and drivability improvements alone were worth the price of admission to me.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2016: 23
pashooter is offline   Reply With Quote
Old 04-22-2016, 10:24 PM   #4
buckeye2344's Avatar
Where can I purchase and what model. I have a 2016 mirada 35bh
Chris and Pam Travis
Massillon, Oh
2016 Coachmen Mirada 35BH
Dog-- Cody (English Labrador)
Cat--Macy
buckeye2344 is offline   Reply With Quote
Old 04-23-2016, 06:14 AM   #5
cpaulsen's Avatar
Did mine over 3 years ago......and works just like Mike says it would!
cpaulsen is offline   Reply With Quote
Old 04-23-2016, 10:30 PM   #6
Former Full Timer
Duckogram's Avatar
Try here. Its on sale.
Custom Dynomemeter Chassis Tuning Products and Services - 5 Star Tuning
Also available from etrailer.com I think.
FYI, What coach you have makes no difference. Its all about
what chassis you have. You will need lots of info for them to
make a custom tune for you. Don't be afraid to ask questions so you
are sure you get the best one for you.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 05-03-2016, 08:39 AM   #7
Roket1's Avatar
Does it void the warranty?
Roket1 is offline   Reply With Quote
Old 05-03-2016, 10:03 PM   #8
Installed one over a year ago, and would not go without it. The shifting is much smoother and less down shifting. No difference in fuel mileage.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 05-04-2016, 07:58 PM   #9
Former Full Timer
Duckogram's Avatar
It can void the engine/trans portion of your warranty however there is a consumer protection law that requires the manufacturer to show a connection between the mod and the failure. That being said, the dealership you go to for warranty repair makes a difference.
Elbert Hubbard
Old 05-04-2016, 08:02 PM   #10
Former Full Timer
Duckogram's Avatar
I talked to 5 Star yesterday and found that things have changed. You no longer need a custom program. The one you get works on MY up to 2015 (chassis not coach) You dont even need the PCM code anymore. Its plug and play!
Elbert Hubbard
