07-24-2021, 11:25 AM
#221
World Wide Wanderer
Originally Posted by Roddor
Wahoonc, at least the enclosed shell is the best part to have even if some of the interior will have to wait. Hopefully the crazy lumber prices will come down. What did you end up with on the garage door width and height, if you don't mind sharing? Pretty close to your rough openings?
The door is 12'wide by 14' tall, I was a tad out of square on the rough opening. But it is close enough.
I have been traveling too much for work again, so I am behind on the wiring on the barn. I need about 3 days and I will be able to get my final. We decided to go with a separate meter rather than try to feed underground from one of the other two meters. I think it will pay off in the long run. We now have 3 sets of 200 amp service on the property.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
12-06-2021, 02:30 PM
#222
Ok guys and gals, this seems to be the expert page on concord. I have a 2016 ds purchased used 2 years ago. It was owned by a 92yo who traded for a 40foot pusher.? Did not take good care of this rig, but we have it I spected,specter, good price. We use it alot. Snowbird in az. I have several issues I do not see addressed...so, here goes, help me if you can.
1. Raised the levelers in the back the last inch available and bought new airbags. I still hit the road on inclines. Thinking about adding wheels...anyone done that?
2.where is the water pump? I think I need to change it. It sounds like a plane landing...is yours loud?
3. Has anyone replace the fresh water inlet? I bought one, bot it seems they are made very cheap, and with the hole at the connection on purpose? I would like to replace with brass.
This is enough for now, I have learned alot reading this thread. Thank you in advance!
12-08-2021, 11:40 AM
#223
World Wide Wanderer
1. They will drag on steeper slopes, there are a set of skids built-in for that purpose.
2. I believe the water pump is under the fridge area, there is an air return there that needs to be removed to access it. Your drain-down valves for the water system are there too.
3. Haven't gotten there yet. I am considering a quick disconnect if I do.
Happy RVing. We love ours and have no regrets after 5 years of ownership. We will be heading out this year for some longer trips with 3 adults and a 60# dog. It will be fun.
Aaron
Aaron & Rhonda
12-16-2021, 09:42 PM
#224
I added wheels to my Forester.
12-22-2021, 01:15 AM
#225
Thank you for the responses. I do have the skids, but the levelers still hit. Where did you purchase the wheels, and where are they attached?
12-22-2021, 06:48 PM
#226
https://www.amazon.com/Ultra-Fab-48-.../dp/B001UGFOXG
12-23-2021, 01:39 PM
#227
Thank you for the info.
