Old 07-21-2016, 01:13 PM   #51
BlackJeep22's Avatar
Originally Posted by wahoonc View Post
There is an option on the inputs on the stereo, you have to toggle through them. I will check when I get a chance and see what mine is set to. It is already set up, just have to hit the correct combination... think slot machine.
Also just as a side note, the ABC zone switch controls the right, left and sound bar speakers. I may rewire that and patch the outside speakers into one of those zones instead.
Aaron
Thanks Aaron! 👍
BlackJeep22 is offline   Reply With Quote
Old 07-21-2016, 02:05 PM   #52
Land of the Midnightsun
jjSpeedwagon's Avatar
I like your dog purch Aaron. Soon after we got Moho I made this ottoman , has table that attaches or comes off for travel. Wheels lock also. I like wood but not much of a cobbler
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-21-2016, 02:07 PM   #53
John & Janice
Old 07-21-2016, 02:18 PM   #54
Table will swivel 360 and table slide out about 16 inches
John & Janice
Old 07-21-2016, 03:42 PM   #55
I also got my double bubble reflective stuff cut for windshield and 2 side door windows. Think air temp is under control
John & Janice
Old 07-21-2016, 04:04 PM   #56
Originally Posted by jjSpeedwagon View Post
Attachment 114858
Enlighten me please JJ.
Old 07-21-2016, 04:15 PM   #57
Well I added extra ac over bedroom. Removed fantastic fan and put in dometic 13,500 btu low pro penguin II. Then ordered a roll of the double bubble reflective insulation and cut it to fit inside of windshield and both side door Windows. And WA-LA. A lot cooler. That all I've done and it works great. When my wife and I were in fredrickburge for the 4th. We sat in wide open sun and it was 105 -107. And the original 15,000 btu ac would only cool inside to about 83-84 and my wife had odd look on her face. So when we got home. I got to ordering another ac and something to put in windshield to cut the heat. Our little thin privacy cover that covers Windows didn't do much to hold back heat
John & Janice
Old 07-21-2016, 04:18 PM   #58
A.C. and eyebrow
Got the AC installed and here is a pic(hopefully ) for Wahoonc of the eyebrow..
Also since The rear view mirror was of no use , I re did the mount for a compass.
Name:	ac inside cover.jpg
ID:	114869   Click image for larger version
ID:	114870   Click image for larger version
ID:	114871   Click image for larger version
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-21-2016, 04:27 PM   #59
Oooooooohhhh hell. Look at you !!! You put ac on backwards. Naw teasin. Good job. I like compass. I use my mirro to watch my jeep. But I like your tint. That slick. I need to do same also side windows
John & Janice
Old 07-21-2016, 04:33 PM   #60
So now there are 4 of us with Concords. That's cool. This forum kind of boring unless you meet others with same equipment
John & Janice
modifications
