Old 07-18-2016, 05:33 PM   #41
Land of the Midnightsun
jjSpeedwagon's Avatar
Originally Posted by wahoonc View Post
LED's are looking good!
I am going to put some under the awning rail, probably drill a hole and fish power from the fridge compartment, or possibly the over the door light. Haven't gotten that far along in the process yet.
Aaron
I ran my power wire down inside the plastic wire trac for the power wire for awning motor and went inside Moho same place awning power went inside. You will come inside behind passenger seat then ran down threw passenger step out underneath and up to battery box. Little wire loom and worked out pretty good
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-18-2016, 10:13 PM   #42
World Wide Wanderer
wahoonc's Avatar
I will look at that as an alternative, where did you put the remote sensor?
I want to split the step light and grab bar light off the over head porch light... eventually. I really don't need the overhead but the grab bar and step light come in handy.
I have requested a wiring diagram from Coachmen, but haven't heard back from them yet. I can figure it out, eventually, but like working from plans and diagrams.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-18-2016, 10:26 PM   #43
+1 on the sewer solution. I also carry a slinky as a backup but haven't had to use it yet either. I like being to flush out the tanks until clear water is running. Still planning on adding a flush system inside the upper half of tank, I hear that is the best way to keep sensors from getting clogged.
Love the rear basket, nice work!
scotttkd is offline   Reply With Quote
Old 07-19-2016, 04:58 AM   #44
World Wide Wanderer
wahoonc's Avatar
Thanks!
My game plan for the sensors is to replace the current system with either a SeeLevel or a Tech-Edge iSeries. Unless I found some compelling reason not to, I am leaning towards the Tech-Edge. It has the ability to set alarms to warn you tanks are getting full or the water tank is getting empty.
Aaron
Aaron & Rhonda
Old 07-19-2016, 05:44 PM   #45
Tbonz's Avatar
Window tint
Took the Concord and had the truck windows tinted and an eyebrow installed,,will make for cooler driving..
And the new air conditioner will be here tomorrow. Plan to install Thursday...Now Momma is looking to replace the couch with dual recliners,,input ???
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-20-2016, 04:19 PM   #46
World Wide Wanderer
wahoonc's Avatar
Got pictures of the eyebrow?
As far as the dual recliners... LayZBoy makes some killer stuff that will fit through the door if you take the backs off. They have some sort of system that they are putting in RV's but I have seen prices in the full K range.
Aaron
Aaron & Rhonda
Old 07-20-2016, 07:19 PM   #47
World Wide Wanderer
wahoonc's Avatar
Got another mod done today, this one was for the hound. He likes to see where we are going for a while, then he wants to lay down next to you. Great companion and will ride for hours and not ask for a potty break.
I built him a platform to go between the seats. It is lightweight and can be easily moved if we need to move to the back of the unit. When we are parked it can be stood on end and used as a storage cabinet. We throw his blanket up on it when we are traveling and he is a happy hound.
Aaron
Aaron & Rhonda
Old 07-20-2016, 07:47 PM   #48
BlackJeep22's Avatar
Very nice.
Thanks, Steve & Deb
2016 Coachman Concord 300DS-SOLD
2011 36QSH TIFFIN PHAETON
Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
BlackJeep22 is offline   Reply With Quote
Old 07-21-2016, 10:45 AM   #49
I admit I haven't looked very far into it, but is there an easy way to get the TV (above the cab) to play through the sound bar and 2 speakers? I didn't see anything obvious on the entertainment center next to the TV.
Thanks, Steve & Deb
Garmin RV 660 MLT
2008 Jeep Sahara
Old 07-21-2016, 12:55 PM   #50
World Wide Wanderer
wahoonc's Avatar
There is an option on the inputs on the stereo, you have to toggle through them. I will check when I get a chance and see what mine is set to. It is already set up, just have to hit the correct combination... think slot machine.
Also just as a side note, the ABC zone switch controls the right, left and sound bar speakers. I may rewire that and patch the outside speakers into one of those zones instead.
Aaron
Aaron & Rhonda
Old 07-21-2016, 01:13 PM   #51
Aaron
Thanks Aaron! 👍
Old 07-21-2016, 02:05 PM   #52
I like your dog purch Aaron. Soon after we got Moho I made this ottoman , has table that attaches or comes off for travel. Wheels lock also. I like wood but not much of a cobbler
John & Janice
Old 07-21-2016, 02:07 PM   #53
John & Janice
Old 07-21-2016, 02:18 PM   #54
Table will swivel 360 and table slide out about 16 inches
John & Janice
Old 07-21-2016, 03:42 PM   #55
I also got my double bubble reflective stuff cut for windshield and 2 side door windows. Think air temp is under control
John & Janice
Old 07-21-2016, 04:04 PM   #56
Attachment 114858
Enlighten me please JJ.
Old 07-21-2016, 04:15 PM   #57
Well I added extra ac over bedroom. Removed fantastic fan and put in dometic 13,500 btu low pro penguin II. Then ordered a roll of the double bubble reflective insulation and cut it to fit inside of windshield and both side door Windows. And WA-LA. A lot cooler. That all I've done and it works great. When my wife and I were in fredrickburge for the 4th. We sat in wide open sun and it was 105 -107. And the original 15,000 btu ac would only cool inside to about 83-84 and my wife had odd look on her face. So when we got home. I got to ordering another ac and something to put in windshield to cut the heat. Our little thin privacy cover that covers Windows didn't do much to hold back heat
John & Janice
Old 07-21-2016, 04:18 PM   #58
Tbonz's Avatar
A.C. and eyebrow
Got the AC installed and here is a pic(hopefully ) for Wahoonc of the eyebrow..
Also since The rear view mirror was of no use , I re did the mount for a compass.
Name:	ac inside cover.jpg
ID:	114869   Click image for larger version
ID:	114870   Click image for larger version
ID:	114871   Click image for larger version
Old 07-21-2016, 04:27 PM   #59
Oooooooohhhh hell. Look at you !!! You put ac on backwards. Naw teasin. Good job. I like compass. I use my mirro to watch my jeep. But I like your tint. That slick. I need to do same also side windows
John & Janice
Old 07-21-2016, 04:33 PM   #60
So now there are 4 of us with Concords. That's cool. This forum kind of boring unless you meet others with same equipment
John & Janice
modifications
