Originally Posted by Bama Rambler
When you remove the heater I think you'll find the connections at the back coming through the wall.
Access to ours is through the pass through. I have to remove a panel on the back wall of the pass through to get to the side of the Girard WH.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
