Old 07-24-2014, 10:41 PM   #1
greenwr's Avatar
Water leak under slide out
Have a 2014 Leprechaun 319DS. Noticed water coming in under the slideout while driving through a pretty heavy rainstorm. After checking, the seal does not touch the side of the MH in the middle. Anyone else had an issue like this? Assume this would be warranty work to get the seal correct. Also had water in one outside storage bin after same rain storm incident.
greenwr is offline   Reply With Quote
Old 07-24-2014, 11:38 PM   #2
I have a 2013 Leprechaun 280 DS and have a similar problem. On the bottom of the main slide there are a few gaps in the seal. They seem to be there for a reason. The problem I found was in storage. My main slide is in the drivers side and my storage spot is uneven and slopes down with the passengers side being the low side. When there was a large rain I noticed water running on the floor from the drivers side to the passengers side. It took me a little time and that's when I found that the rain was entering the front gap in the seal. I leveled the motorhome and have never had any water coming in as long as it's level. Click image for larger version
Name:	ImageUploadedByForest River Forums1406262999.278810.jpg
realredrebel is offline   Reply With Quote
leak, slide, slide out, water, water leak
