Old 01-14-2017, 12:22 PM   #1
Water pump
Looking for opinions/experiences of others... Sportscoach 405FK with washer and 1 bathroom. Need to replace the water pump. What gpm and psi should I be looking at? We seldom dry camp. Maybe 1 or 2 nights on the road at a WalMart or rest area while enroute to a destination. Tankless hot water if that makes a difference. Thanks in advance.
Bill & Beth
Hyde Park, NY
2014 Sportscoach Cross Country 405FK
2015 GMC Acadia
afd51 is offline   Reply With Quote
Old 01-14-2017, 02:55 PM   #2
I would go bigger (gpm) than what came in the unit. In this situation, in my opinion, size does matter. I replaced mine with a variable speed, larger gpm unit. My tt is in storage now so I can't tell you what unit I used.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 01-17-2017, 06:34 AM   #3
Just a thought. Because you are having to go into it anyway regardless of what pump you install you may want to look at installing a pulse dampener tank at the same time.
KAttkisson is offline   Reply With Quote
Old 01-17-2017, 07:41 AM   #4
Your only need is the correct pump for your "Water Heater" that is determined by "Type/Series/Model#/Serial#/MFG" of the Heater! Some are "Touchy" even when hooked to City Water! I don't think you will be doing much "Washing and Drying Clothes" at Wal Mart,I could be wrong! Youroo!!
pump, water, water pump
