Old 04-27-2013, 11:22 AM   #1
Roll's Avatar
Water pump isolation project: Done
This post is not for GoSix to read. (DH secrets revealed.)
Old Coot, (who owes me a cup of coffee), said the answer to my problem, (water pump making noise when I used the toilet at night) err, the DWs problem really, which made it my problem, was to isolate the water pump.
From the factory, it had been attached directly to the wet bay back wall which is metal. It was on rubber grommets but nonetheless it was loud and annoying to use, the sound carried through the coach and anyone nearby could here it.
Last year I replaced the original pump with a high end SurFlow that among other things was labeled "quiet". Not much improvement.
So my friend that owes me a drink (OC) said the solution was to mount the pump via rubber grommets, on plywood and then mount the plywood via rubber grommets of its own, on the floor of the wet bay which is a softer material than the metal wall.
Here are the pictures which I provide least my friend suggest I did not actually do this project.
If Old Coot was right, the DW should be happy and if she is happy I may get ........ Well if that happens I'll owe him a couple coffees.
ID:	29060   Click image for larger version
ID:	29061   Click image for larger version
ID:	29062   Click image for larger version
ID:	29063   Click image for larger version
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 04-27-2013, 11:35 AM   #2
Looks good and I'll wager a cup of coffee your (DW's) problem is solved. You did a very nice job, neat, clean and organized other than the kink in the slinky. LOL
Old 04-27-2013, 12:24 PM   #3
Roll's Avatar
Thank you.
That big pipe only holds so much slinky so if you want to improve your range..... you push it up from the bottom and there you go.... a kink.
I have extensions but I hate to use them.... I am never unable to avoid some mess when I have to add sections.
Roll
Old 04-27-2013, 12:38 PM   #4
Originally Posted by Roll View Post
Thank you. Roll
So why have you not had your TOWTA give the fix a yes or no?
Old 04-27-2013, 01:55 PM   #5
Roll's Avatar
Towta?
Old 04-29-2013, 12:32 PM   #6
go6car's Avatar
Of course I HAD to read this now, LOL!!!!
2013 Coachmen Encounter 36KS
(Forest River adopted cousin! )
2004 Jeep Wrangler
go6car is offline   Reply With Quote
Old 04-29-2013, 12:34 PM   #7
Towta?
The One With The Authority. Wife.
