Old 04-01-2014, 04:37 PM   #1
Water Pump Location
Can anyone please tell me where the water pump is located on my 2013 Coachmen Freelander (19'), and how to access it?
George M is offline   Reply With Quote
Old 04-15-2014, 11:48 AM   #2
water pump
Water pumps are supposed to be located within 6 ft. of the fresh water tank. On my 2013 Grey Wolf (Cherokee) 28BH it is mounted under the lavatory sink behind a plywood panel which is held in place with 4 small screws. You could also try turning the pump on and locating it by the noise; but be careful that you DO NOT run it dry, so there must be water in the fresh water holding tank.
Marshall and Tania
2013 Forest River Grey Wolf 28BH
2002 Chev Silverado 1500 4X4 Z71
biker2 is offline   Reply With Quote
Old 04-15-2014, 05:17 PM   #3
B D HOWie's Avatar
Our Freelander 28QB has the FW tank and pump under the bed near the low point drains. The top of the bed has a hinged access.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 04-15-2014, 05:24 PM   #4
Rupkin2's Avatar
Marshall and Tania
Good to know, the 6' part. Something I never gave any thought. Only makes sense to be close to the tank.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 04-15-2014, 05:37 PM   #5
Spikedog's Avatar
ON the 26' Freelander it's under the stove. You can also get to it by removing a grating under the stove. It's buried way back - not the most user friendly spot.
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
Old 04-17-2014, 06:40 PM   #6
Hey Paul,
Have you made any headway on moving the fresh water tank drain valve?
Have you made any mods to your 28QB that you would like to share with me?
Tim
Healeyman is offline   Reply With Quote
Old 04-18-2014, 09:32 AM   #7
B D HOWie's Avatar
I have made a couple mods.
1. In stalled manual step. Click image for larger version
Name:	ImageUploadedByForest River Forums1397830114.909621.jpg
Name:	ImageUploadedByForest River Forums1397830164.329002.jpg
Name:	ImageUploadedByForest River Forums1397830209.423826.jpg
I would like to find an automatic step but the extra outside depth below the door is an issue.
Also installed struts to hold dinette seat up when accessing storage.
Name:	ImageUploadedByForest River Forums1397830506.195586.jpg
I plan to add one or two struts under the bed access.
Name:	ImageUploadedByForest River Forums1397830613.388061.jpg
Name:	ImageUploadedByForest River Forums1397830682.586375.jpg
I will have to remove some of the top plate in the first picture for the strut to fit. Will add additional vertical support below and to side of where i notch top plate.
You can see the top of the water pump in that picture also.
I also made a filter for the heater return. Having two dogs needed to control the hair getting to the heater.
Name:	ImageUploadedByForest River Forums1397831261.043322.jpg
Name:	ImageUploadedByForest River Forums1397831288.482064.jpg
This is the back side of return. There is still a one inch plus opening at the top when installed so I do not expect much restriction in air flow.
Paul
Paul
Old 04-18-2014, 09:38 AM   #8
B D HOWie's Avatar
Healeyman
No, I have not moved it yet. Any updates on how your mod worked?
Paul
Paul
Old 04-18-2014, 10:15 AM   #9
B D HOWie's Avatar
Sorry, do not mean to highjack the thread.
Paul
Paul
Old 04-18-2014, 12:07 PM   #10
Paul,
PM to you.
Tim
cat, location, pump, water, water pump
