Old 03-27-2014, 01:40 PM   #1
Commercial Member
Water pump replacement How ?
Is it possible to replace the water pump on 2008 Coachmen Freelander (Freedom Express) without removing the shower and cutting through the bathroom floor?
I want to do something about the excessive noise of the pump. The OE pump is screwed down hard. This makes the floor a sounding board so all vibration gets amplified.
I can see no way to access the screws used to install the pump as it appears the pump was installed before the floor of the bath was installed.
Local dealer - Camping World, will not stand behind their advertised "$39 Install" for a water pump.
While at it I want to R&R the "Water box" so I can remove the rust. I can only paint over the rust so many times.
It appears I need to disconnect something from backside but of course can not access the backside because the water pump is in the way.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 04-03-2014, 07:52 PM   #2
Roll's Avatar
I can not help but did want to offer.... "Wow and I thought my pump was hard to get at."
If you can't get the pump out, can you get to the lines and just disconnect it. Then install a new pump on an isolation board wherever you can fit it in and extend your water lines to the new pump. Just leave the old one in place. You could even cut the water lines and splice new, longer line to the cut ends.
I imagine you already thought about this.
Gary
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 04-12-2014, 05:31 AM   #3
B D HOWie's Avatar
Tireman9, just curious if you have been able to put the new water pump in. Our 2013 Freelander QB28 has the fresh water tank under the bed. The bed top hinges for access to the FW tank, WP, and low point drains. Not sure this will help just an option to consider if you have access.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is online now   Reply With Quote
pump, replacement, water, water pump
