12-03-2017, 08:13 PM
Water Volume From Kitchen Faucet
We have a 2015 Coachmen Mirada 35LS and since delivery have never had a good volume of water from our kitchen faucet. The other faucets seem ok - shower weak but acceptable. Water pressure near 60 psi. Techs can never find anything wrong - aerator clean & no kinks in hoses. Anyone else experience this?
12-03-2017, 08:36 PM
We had a similar problem with our kitchen faucet. Found a check valve like device in the flex line just after the control valve to hose. Removed it and had move flow and pressure.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
12-03-2017, 10:32 PM
Have the same problem in a 35 BH - 2016. Planning on new faucet next spring.
12-04-2017, 12:20 PM
ResQfrog - couldn't find anything on flex line except the weight. I loosened that just in case it was choking off some water flow but didn't seem to help. May have to try new faucet also as gooseneck is really hard to swivel.
12-04-2017, 12:25 PM
The check valve or restrictor was at one end of that flexible hose. Had to remove the hose to find it. It looked like a plastic bullet. Can't remember which end of the flexible hose it was at. Sorry.
FROG Member
12-04-2017, 12:31 PM
Could your problem be something as simple as a clogged aerator in the faucet? The aerator screws in to the end of the faucet, and has a metal screen (or screens) and usually some plastic components. Twist it off and give it a look.
Joe
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
12-04-2017, 02:08 PM
Had a similar problem. Loosened a set screw where flex hose attaches to faucet assembly to take off. Found plastic material like Teflon tape or shrink wrap in this tight passage. Removed debris and all was good.
After thought, check all connections for water as they can jiggle loose over time and road vibration.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
12-04-2017, 02:09 PM
We had same problem. The water line under sink had a small bit of plywood in line.
BTW. The trailer was brand new.
12-04-2017, 09:18 PM
rtc830
Check the strainers in the faucet head. Had same problem and for some reason there were 7 strainers in the head. One would do the job.
12-04-2017, 09:34 PM
Check the strainer in the city water hook up. If not there, I would replace the faucet, we did in our 2015 Encounter, made a difference.
12-05-2017, 01:45 AM
Aerator clean. Removed the sprayer and water came out with much greater force and volume. Couldn't take sprayer head apart enough to find restriction so will try to change aerator first even though current one looks clean and failing that see if I can get a new sprayer head.
12-05-2017, 07:30 AM
"On the road again"
We had a similar problem with our 2017 Cardinal. Turned out the weight to pull the faucet back into the "neck" wasn't placed at the proper position and was causing a serious kink in the flex hose. The kink was very hard to see at first - so look closely.
I loosened up the screws for the weight - moved it a few inches and that resolved the problem completely.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
12-05-2017, 10:26 AM
Same problem on my Crusader. Just a trickle when faucet was "docked", but water stream would increase when pulled out. Weight was causing a "kink" in the hose. Moved the weight a few inches and suddenly it worked. They install those faucets to the counter top before putting the counter top on the island so had to cut an access hole in the back of the cabinet to get at it. May look into replacing faucet as so many others have talked about how much better other faucets are.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
12-05-2017, 11:14 AM
Just a couple of things since you mentioned them. Might consider changing out shower head for a Oxygenics. The best bang for the buck I ever spent. Also if your unit does not have a water pressure regulator you might consider putting one in. Don't think I would want to go much more than the 60 psi you already have. Gook luck.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
12-05-2017, 11:33 AM
Empty Nesters
X2
2017 Sunseeker 2250 24' MH
12-05-2017, 06:17 PM
Dahagen
I replaced two faucets on my 2013 Mirada. Apparently, the thin copper pipes kept clogging. I replaced the second faucet with one that had standard home style water lines and did not have a pull-out faucet. So far, so good.
