Old 08-30-2014, 08:47 AM   #11
Had our Coachmen Pursuit 31BDP weighted after the FROG rally this year on the way out and got the following weights. Unit had a full fresh water tank and both the gray and the black tank empty. Had more stuff than would normally carry if we were going for a weekend. Purchased to much stuff to take home just like last year. Also had the tow dolly and car hooked up.
Weights were by the Recreation Vehicle Safety Education Foundation.
LF=3125 lbs RF=3000 lbs Total= 6125 lbs Rating= 7000 lbs Reserve 875 lbs
LR=5500 lbs RR=5550 lbs Total= 11050 lbs Rating= 12000 lbs Reserve 950 lbs
Vehicle Gross weight 17,175 lbs
GVWR 18,000 lbs
Reserve 825 lbs.
Being the sticker in the cab area shows a CCC of only a little over 2200 lbs capacity we did OK.
The 5th wheel after us did not do so good. Front axle was good rear axle was way over and trailer sounded real close.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
