09-14-2014, 07:30 AM
Wet bay heater for Encounter
Has anyone tried to set up a small electrical heater to keep the wet bay warm in cold weather?
Last March the DW and I were unexpectedly caught in a cold snap in Huntsville AL. Temps dropped down to the 20's. I was certain it was going to freeze our water lines or at the least, the lines in the wet bay which get no heat from the coach.
Well, we got lucky that time around but if it happens again, we might not be so lucky.
I can't do much about the water tanks but I could put a small electric heater in the wet bay for emergencies like that night in Huntsville.
Wondering if anyone has tried to rig something up?
Gary
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2018 Wrangler Unlimited Sahara (JKUS). Many upgrades, additions, mods, and changes to the coach.
09-14-2014, 07:44 AM
I take it you are worried about the water inlet and supply hose.
You could just buy a heated hose.
Amazon.com: heated rv water hose
Or you could wrap the hose you have with some heat tape and then cover that with foam pipe insulation from Home Depot or Lowes.
As for the box it's self I would just wad up as much newspaper as it will hold.
09-14-2014, 11:18 AM
For a quick and temporary heater you could always get a trouble light and put a 60 or 100 W light bulb in it and hang it in the wet bay.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
09-14-2014, 04:11 PM
We were on the water tank supply and did not have a water hose attached but your comment about a heated water line is a good suggestion. As for the newspaper I am lost. Do you mean to fill the wetbay with newspaper, see below.
09-14-2014, 09:10 PM
Cyclone
I added an outlet in our bay in the Berk and use a small 2000W heater with a thermostat. I'm not sure if you have room for that. If your at a campground you can use the extra 20 amp outlet on the pedestal and run another extension cord through the access to power it.
We used a 100W light in the well pit at home for years.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
09-15-2014, 06:06 AM
Question
I have a Berk and have been thinking of doing the same thing. Mount the heater in the pump side of the bay. Do you have any concerns regarding getting the plastic tanks to hot on the end where the heater is mounted? Do you think the heat will migrate to both sides of the bay? I do not want the manifold to freeze.
My other thought was to mount a light at each end of the bay but not sure how long we will be able to buy incandescent light bulbs as they are supposed to be phased out.
09-15-2014, 07:12 AM
On our Coachmen Pursuit they have a small 2" hole at the top of the compartment were they ducted the air from the furnace to warm the compartment. Look in behind that panel for one. We do not have the heat pads on our tanks. I did place a small fan in the compartment were the duct came in to blow some air across to the other side. I then purchased one of the remote temp monitors so I could check to make sure it stayed above freezing.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
09-15-2014, 08:17 AM
This is what I did and it worked out great, just used a cheap extension cord and closed the lid. Then I didn't need heat on or my tank heaters. I have always disconnected my water hose and put it inside and used the fresh water pump at night. Have you ever priced the cost of a heated hose and heat tape for the riser? Out of my ball park just for an emergency. Even if you tape the riser it will not guarantee you water if it freeze's before your water line connection......
Coachmen M/H
Concord
2018 / 300 DSC
09-15-2014, 04:30 PM
Some good ideas thanks.
I was leaning toward doing this: Wiring a 12v lead into the wet bay and connecting a permanently attached 12v heater. I would put a switch and warning light in the footwell so I know its on and can switch it off from inside. My wet bay compartment is mostly sealed with the only openings for the hoses going in and out. No cutouts for heat.
I'll also add a temp sending unit so I can monitor the compartment.
09-15-2014, 04:55 PM
We run on our on board water --set thermostat at 72 and leave coach closed up. (Slides in). Have run at low as 3 degree a couple times. Never had a freeze issue??
Russell.
09-15-2014, 05:16 PM
Wadded up newspaper is a good insulation.
How ever given the size of yours perhaps some ridged foam cut to fit to insulate it would be a better idea.
09-16-2014, 06:10 AM
Russell.
Do you have a heated basement?
09-16-2014, 06:21 AM
On the RV I had last year I had a 2" hole that blew heat into the basement. The new RV has heated tanks I think. Haven't looked into that yet as I don't plan on being in cold weather this winter.
I believe the big thing is to heat as little space as possible. So we keep slides closed. With your slides extended you will be exposing more water lines to the elements.
Russell
09-19-2014, 07:50 AM
"Slides in" is an excellent idea for when temps drop below freezing. It didn't occur to me to pull them in when we were in Huntsville, but I will do so the next time we get caught out in cold temps.
Still does not solve my wet bay issue. I think I'll look into what might be available in a small 12v heater that I can install in that area.
Not to sound like a broken record but our coach does not have a heated basement, meaning our tanks are not heated nor is there any heat provided to any areas below the floor.
I can't tell from the many responses if the suggestions are coming from folks that do have heated basements or like the DW and I, do not have heat to the basement area.
Thanks all
Gary and Cindy
