Old 06-06-2015, 07:47 PM   #11
Former Full Timer
Duckogram's Avatar
Dennise,
Here is the "Fix" I used. You can find more info at Camco.net.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 06-07-2015, 05:16 PM   #12
Cool
[QUOTE=Duckogram;885680]Dennise,
Here is the "Fix" I used. You can find more info at Camco.net.[/QUOTE
Thanks for the tip! Camco's 'Hybrid Heat' looks to be a nice way to add electric water heating.
Do you know if the included ON-OFF switch switches the 120 VAC to the unit directly, or alternately, is a relay included in the kit so that a remote 12 VDC source can switch the 120 VAC power ON 'n OFF?
Has anyone added Camco's Hybrid Heat to Atwood's G6A-8E LPG hot water heater?
2015 Coachmen Prism 2150LE
MBenz Sprinter Chassis
Dennise is offline   Reply With Quote
Old 06-07-2015, 05:57 PM   #13
That's correct and I was advised by my dealer to replace the cotter pin after each use. To prevent accidental turn-on of water heater from the inside.
gravel is offline   Reply With Quote
Old 06-07-2015, 06:58 PM   #14
Former Full Timer
Duckogram's Avatar
If you are referring to the post by Yarome, there is no cotter pin or outside switch. The OP has the Atwood LP DSI 6 gal water heater.
Old 06-07-2015, 07:21 PM   #15
Former Full Timer
Duckogram's Avatar
[QUOTE=Dennise;886435]
Originally Posted by Duckogram View Post
Dennise,
Yes, I installed the Camco Hybrid on my 2013 vintage Atwood G6A-8E water heater. I did not put it on a hot water heater because I saw no reason to heat hot water.
It comes with the heating element (rod), rocker switch (illuminated), wiring, thermostat with safety sensor and very simple instructions. Installation requires
drilling a hole in water heater frame under the point where the propane line comes in. You must also cut the styrofoam on a flat part of the water heater tank to mount the thermostat with the 3M tape which is included. I installed mine in March of '14 with a full 20 gal tank of propane. I now have 3/4 of a tank after 4 MONTHS of traveling and 13,000 miles and have spent $0.00 on propane.
You do have to plan a bit to manage the hot water as the Camco is only 475W as tested. Thats about 1/3 of what a factory WH draws. Also noteworthy is that I installed an electrical box under the floor and wired it to the breaker box. The camco has a standard male 120v w/ground plug on the pigtail. As a bonus, I now have an outlet under the wardrobe where I can plug in a shop light so I can see down the cable chase. You probably dont have one of those.
Edit: I did cut the wires about 4" from the element and installed a 2 prong waterproof plug. This allows for easy removal of the element assembly for draining the tank and also acts as a safety when the tank is empty.
Old 06-08-2015, 11:29 AM   #16
Cool
[QUOTE=Duckogram;886582]
Yes, to make the thermostat sense the water temp accurately. Do you know if the "flat part" is accessible from the outside of the control box by removing parts there? Or is the flat part only accessible from inside the coach (very difficult in my Prism ... I'd need a highly trained and motivated Capuchin monkey to do it )?
Old 06-08-2015, 11:35 AM   #17
Former Full Timer
Duckogram's Avatar
Get the Monkey. Mine is accessible through a removable panel under the wardrobe. The thermostat mounting point is burried under the duct tubes. I had to remove all the ducting and use a mirror to get to the back of the tank where there was a suitable mounting flat spot. I was black and blue for days afterwood. The top of the photo is the back of the WH.
Old 06-08-2015, 11:36 AM   #18
Former Full Timer
Duckogram's Avatar
Here is what the front looks like:
