Old 10-17-2013, 03:13 PM   #11
Pathfinder75's Avatar
My 2012 Leprechaun 319DS did not have jack or wrench. Tire and Rim were included in a package option or they would not be there either. I purchased a 12 ton bottle jack and a 1/2" breaker bar (stronger and longer handle than Ratchet) with proper size socket for lug nuts to carry with me. I was fearful if in a out of the way boon dock camp that road service may not be prompt if they came at all.
Dealer told me because of tire size on motorhomes people always call for service.
May be so on larger Class A but a Class C is only a 16" rim. That is not any larger than a typical 3/4 ton pickup.
I have Rotated mine once ( rotation is another subject though, some for and others against) and not thinking briefly used a 3 ton service jack on wheels to attempt to lift the rear duals. I woke up quickly realizing the vehicle weight and switched to the 12 ton with no problems.
If you can change a pickup tire then you can change a Class C tire. Duals just have two rims behind same lug nut. Remember axle weight of unit when getting a jack.
2017 Montana HC 353RL
2017 Ford F350 6.7L Dsl., CC, SWR, LB, B&W Companion #BWRVK3300 OEM Prep mtg.
Traded- 2012 Coachman Leprechaun 319DSF
retired-Towed -2011 Chevrolet Equinox 4-cyl. AWD
Pathfinder75 is offline   Reply With Quote
Old 10-17-2013, 09:25 PM   #12
bayne44freelndr's Avatar
same situationm ...
Originally Posted by bayne44freelndr View Post
I was told jack and lug wrench are a legal liability ... so, not provided to prevent law suits. That's what road side service is for. Of course, that assumes you are in an area where assistance can be contacted ... not remote camping without phone or even GPS. Let the games begin!
I was told the same at COA in Middlebury. I've since been camping in 3 places with neither cell nor gps service. I have a spare, but will have to get the wrench and jack on my own. As to liability ... my wife would definitely be coming after someone if we were stranded and I croaked on her.
bayne44freelndr is offline   Reply With Quote
Old 10-17-2013, 09:26 PM   #13
same situation ...
Old 11-30-2013, 08:23 PM   #14
If you want a factory Ford E450 jack, handle, lug wrench, and instructions just go online (EBAY) and you will find new takeouts being sold for about $60. It's designed for the Econoline 450 and is much lighter and easier to use than a short handled heavy bottle jack. Guess they are coming from Box truck conversions since RV manufacturers say jacks are not supplied from Ford with the RV prep package. I also purchased a spare tire winch so I don't have to crawl under to unbolt the spare.
ATVer is offline   Reply With Quote
Old 11-30-2013, 09:33 PM   #15
43D18's Avatar
I'm not aware of any new coaches being shipped w/ jacks or spares these days, with the exception of smaller class C's and B plus units
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 04-15-2014, 05:52 PM   #16
Spikedog's Avatar
Having handled 2 blowouts on my old El Dorado (one that completely destroyed my wheel well), I've got some advice.
Get an electric impact wrench - you can get a good one from harbor Freight for under $40. You can run it off the generator, and it'll break loose that big lug nut that's probably torqued to well over 125 ft-lbs. Buy 2 bottle jacks. Not one, TWO. That way when one starts to sink in the ground you aren't stuck. Make sure you have the correct impact socket. Don't use regular sockets - you need specific for impact wrench use. Don't wait until you get the flat tire to try everything out.
You need:
2 bottle jacks (hefty ones too)
extension cord (at least long enough to reach from the outside outlets to the tire farthest away)
Impact deep well socket
Oh yeah, better have a spare tire too (that's got air in it). Check it once in a while...
Best case scenario - you never need it for your rig, but are right there for a fellow RV-er.
2007 Coachman Freelander 26' w/ E-450 6.0L diesel
1982 El Dorado Bermuda 27' w/ E-350 460 gas (sold)
Spikedog is offline   Reply With Quote
Old 04-15-2014, 05:59 PM   #17
43D18's Avatar
The best advice I can offer is to get Good Sam Emergency Roadside assistance (or companynof your choice) and use the space you would otherwise use to store jacks and other equipment for party lights, beer, etc
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 04-15-2014, 06:15 PM   #18
Former Full Timer
Duckogram's Avatar
x2
... and don't they all come with a year of coachnet?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 04-30-2014, 12:46 PM   #19
I carry some short pieces of 2 X 6 to put under the jack so it does not sink in soft ground.
Sent from my SCH-I545 using Forest River Forums mobile app
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 04-30-2014, 12:59 PM   #20
mjones12's Avatar
Originally Posted by Duckogram View Post
x2
But if your car was never equipped with a spare, what do AAA and CoachNet and Good Sam do when they get there to help you? Maybe they carry "fix-a-flat" like in Lou's car.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
