Old 11-04-2015, 05:53 PM   #1
Commercial Member
Winterize 2016 22QB warning
If you have a new 22QB do not try and follow the instructions from FR that are titled 2015 Winterizing. The pictures in that document do not represent what Coachmen is actually building.
Here is the low point drains
Here buried behind the heater ducts are the Hot water tank by pass.
The water pump is not near the shower per instructions but behind a panel in the Basement
Close-up of the pump
Now I haven't worked out how to install the CAMCO By-Pass kit as Coachmen decided to mount the input line tight against the drain line.
The fitting they suggest we use is a special order part so if you decide to go that route plan ahead.
When / if i figure out how to install the by-pass kit. I will post the information here.
Good Luck
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 11-16-2015, 09:03 AM   #2
Tireman9, I'm a member of the Forest River marketing dept. The team at Coachmen can help clarify this issue for you. Please contact Ron Ross at rross@forestriverinc.com or (574) 825-8602. He'll be happy to help.
esimmons12 is offline   Reply With Quote
Old 11-17-2015, 07:26 PM   #3
Commercial Member
Here are some shots showing the clearence FR allowed for service of the water pump.
Note that this 6-1/2" is for the two easy screws. The other two have only 5" for the 1" screw + driver + your hand.
FR has admitted the pump needs to be moved to allow the suggested fittings (special order from FR dealers) be installed to allow the pump to allow suction of antifreeze into the lines. I would challenge someone from FR to "move" the pump in under a couple hours without spending $50 to $200 on special tools.
Starting screws into the floor without pilot holes should be interesting.
winter, winterize
