Old 10-20-2014, 09:10 AM   #1
meg
Winterizing 2011 Mirada
Need to winterize Mirada but can't find Hot water tank bipass. What a pain have to winterize everytime you use MH. We need to winterize in a few weeks but want to use MH some in winter so everytime you have to drain and re-winterize??! Any suggestions?
meg is offline   Reply With Quote
Old 10-20-2014, 09:42 AM   #2
TURBS's Avatar
Well if you don't want the lines and drains to freeze then yes you have to winterize.
Wh bypass will be directly behind water heater.
If I was you I'd drain wh then bypass.
Drain low point drains.
Then buy the blow out adapter that hooks to your city water connection then just blow the lines all out.
Buy I gallon of rv antifreeze and pour a cup or so in each drain and then some in your toilet.
Shouldn't take more then 30 minutes TOPS!
Turbs
Old 10-21-2014, 10:45 AM   #3
Leprechaun313QB
dcooke570's Avatar
I have a 99 leprechaun and I can't find any bypass valves either for the water heater. The manual says look under the sink but I don't see any bypass controls under the sink.
dcooke570 is offline   Reply With Quote
Old 10-21-2014, 11:16 AM   #4
TURBS's Avatar
Can you access the back of your water heater?
There may be a false panel.
Turbs
Old 10-21-2014, 11:39 AM   #5
Leprechaun313QB
dcooke570's Avatar
There is a panel under the oven with screws. I'll have to check tonight to see if valves are behind it.
Old 10-21-2014, 11:41 AM   #6
TURBS's Avatar
"Normally" the valves are directly behind water heater.
Turbs
Old 10-21-2014, 06:12 PM   #7
Leprechaun313QB
dcooke570's Avatar
Bingo… found it behind the panel below the oven!!
Name:	ImageUploadedByForest River Forums1413933114.945497.jpg
Old 10-22-2014, 06:05 AM   #8
TURBS's Avatar
Attachment 65139
Very good!
Turbs
Old 11-04-2014, 10:12 AM   #9
by now, you probably have located the hw bypass. I have a 2014 Mirada 29DS and was stumped too. found access from the storage baynext to the hw ...a metal panel w/ 6 screws. SOOO proud of myself because nowhere in my documentation/owners manual did i find how to find the "behind" of the hot water heater!!!
gomalley is offline   Reply With Quote
Old 03-12-2015, 12:33 PM   #10
I have a 35ds Mirada with an access panel outside in the storage compartment just next to the Water Heater. If you can't find it inside then check outside for a hidden panel with screws holding the panel in place.
sheltonbh1355 is offline   Reply With Quote
2011, winter, winterize
