Old 04-02-2015, 04:05 PM   #161
Blackhat6mike's Avatar
My Aviator Wright Flyer had a second A/C [bedroom] installed at the dealer. The styrafoam insulation made it difficult, but not impossible. All controls are ON the unit and not on the wall where the vent/fan control was. That slab styrofoam is hard to "fetch" wires through, but works great as insulation. Haven't used 2nd A/C since we bought the unit.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-03-2015, 11:09 AM   #162
KenHwy61's Avatar
I am posting this photos on behalf of Blackhat6mike. He has done a lot of work solarizing his Aviator. Very well done.
He also had some tire issues so keep an eye on yours.
Name:	Eddies av 1.jpg
ID:	72940   Click image for larger version
Name:	eddies av 2.jpg
ID:	72941   Click image for larger version
Name:	eddies av 3.jpg
ID:	72942   Click image for larger version
Name:	eddies av 4.jpg
ID:	72943   Click image for larger version
Name:	eddies av tire blowout.jpg
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 04-05-2015, 08:07 PM   #163
BamaCamper
cjearle2's Avatar
We will have to find another dealer to try it then. How long have you had your unit. We are concerned with our tires. Did you put some miles on yours before this happened. We were thinking about upgrading our tires before going to Goshen. Great job on the Solar panels.
Aviator Wright Flyer 1912
F-250 2014
cjearle2 is offline   Reply With Quote
Old 04-05-2015, 08:26 PM   #164
We had about 3,000 miles on the tires before they blew out. No bumps, curbs or low inflation or overweight, just crappy tires. JUNK!
We have had our Aviator for a year and a half and are truly in love with it. I've gone full solar as the pix show, but getting there took time as I ran into two bad transfer switches and a bad inverter from the git go. Got everything online and haven't looked back since. Still looking into a 5th bat, but that is down the road. The Aviator is already tongue heavy.
OBTW, I think you will find Renogy a great company to do business with. They were a super help in putting together my system even helping with components they didn't make [auto transfer switch and inverter].
Also, we moved up to E rated tires.
Old 04-05-2015, 08:56 PM   #165
KenHwy61's Avatar
What tires did you go with? Mine have been ok so far but I would like to upgrade at some point. Also noticed your roof is white. Mine is silver like the top of the sidewalls. Just another of the little differences I've noticed like having 2 or 3 front hood latches or having 1 or 2 latches on the outside baggage doors. The wright-flyer is definitely tongue heavy. I may have to upgrade my hitch as it rated for 1200# tongue but the WF is over 1500 with a tank of fresh water.
2012 Ram 2500HD CTD
Old 04-07-2015, 07:40 AM   #166
BamaCamper
cjearle2's Avatar
We are going to have to upgrade out tires. Just looking forward to getting it back thursday.
F-250 2014
Old 04-07-2015, 02:26 PM   #167
snowtosurf's Avatar
Hi everyone! It's official the Aviator arrived last night from Alabama and we could n't be happier )))
I have another question: What is the proper way to raise the dining table and lock into place. After much trial and error I finally got it to work but to be perfectly honest... I don't know what I did!
Melissa
snowtosurf is offline   Reply With Quote
Old 04-07-2015, 02:53 PM   #168
Rivnut
Rivnut's Avatar
Table
Melissa;
Our is an Electra, not sure about yours. Our table raises by putting a foot on the floor leg, grab the table top and swing from the side up. Stumped me too at first, but the wife figured it out. Store folded upside down on the couch, strapped in by the hidden straps found behind the cushins. When I got mine the table was floppin around on the inside causing them to replace the fridge door. Be careful about that darn water filter. read the postings, replace it or just remove it, or use a bar under it to remove and install, strange threads on the filter head.
regards
Charlie and Gail
Rivnut is offline   Reply With Quote
Old 04-07-2015, 03:11 PM   #169
snowtosurf's Avatar
Hi Charlie and Gail, we have the Wright FLyer and it has this big round table with hydraulic lift, it sounds as if yours may work differently but thank-you for the answer anyways! It appears our water filter was already removed, found it in a drawer
Old 04-07-2015, 07:45 PM   #170
KenHwy61's Avatar
Melissa
Congratulations on getting it home! As far as your table goes, sliding the handle to the left pulls a pin that lets the table lower or raise. I added a bracket to guide the handle and replaced the 2x2 supports with 2x6s for added stability when used as a table. I also added legs that lower when used as a bed (see picture) Once raised be sure to push down on the table to make sure it is locked in place. Travel with the table lowered. Feel free to ask any questions. We as a group have learned a lot about how the Aviator was put together and how everything operates, quirks and all.
Name:	av table.jpg
2012 Ram 2500HD CTD
