Old 11-14-2019, 11:17 PM   #1
AWF 1957
dshome's Avatar
Aviator rear pass through sliding tray
The following photos are of a tray I assembled to slide either direction. The tray rides on HDPE (high density polyethylene) or cutting board strips. The top is held down by the quarter round so it does not tip up when extended. I have a material list with dimensions somewhere and will add it later. The sterilite containers fit snugly and pass through the opening without touching. The side rails are screwed down through the bottom rail with additional "El" brackets for support. All wood to wood surfaces were glued and screwed.
ID:	219198   Click image for larger version
ID:	219199   Click image for larger version
ID:	219200   Click image for larger version
ID:	219201   Click image for larger version
AWF #1957
dshome is offline   Reply With Quote
Old 11-16-2019, 07:04 PM   #2
AWF 1957
dshome's Avatar
Here is an attachment of the photos in the correct orientation.
AWF #1957
