Old 06-20-2016, 08:49 PM   #91
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Ken. The trees in my yard are well over 100 ft as we are in "Pine Mecca". Being a ham operator that has been hit by lightning three time at my station [total lose each time] a dish on top of a tower is a no no.
Called the tree guy Saturday for an appointment come Monday. I want to get the satellite dish guy out here first to see what limbs or trees have to be removed before I install the satellite equipment here at the house.
My satellite guy saved me $500 [$750] on an automatic antenna that can travel with us on the road. "Aim and shoot" is what he calls it and IT WORKS! Even has a handle to carry it. Bought one controll box and a wireless device that allows TVs to operate without a coax cable. I'm on the $49 a month plan with an additional $9 a month for the "New York Plan" which has all the channels I watch, plus a few hundred I don't. Soooo happy to get away from Comcast cable.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 06-20-2016, 10:06 PM   #92
KenHwy61's Avatar
I guess you don't want I lightning rod attached to your house! I see those portable dishes around quite a bit. They seem especially popular with the big coaches and full-timers. We have satellite at our home and maybe once we hit the road more frequently we will get the portable set-up too.
Still getting lots of attention as people pass by and ask about the Aviator. Even had an Airstream owner stop by last Friday. They were intersted to learn it was built to compete with Airstream. All say they never have seen one before. I tell them with only 70 made they might never see one again!
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 09-19-2016, 08:26 PM   #93
KenHwy61's Avatar
Back to the mods!
Brought the camper home from our seasonal site and thought I would post up a few more mods. I added 12v fans with variable speed mounted above the bed. Nice breeze and white noise. Since they run on 12v, they can be used anywhere. Also added a manifold to switch between my two freshwater tank. On the side of manifold is a Schrader valve fitting to allow me use compressed air to easily winterize from inside the camper. To run a 12v compressor or other accessories, I added a high amperage 12v connection point. Also added a convenient switch to turn on and off the electric water. The fun never ends!
ID:	120734   Click image for larger version
ID:	120735   Click image for larger version
2012 Ram 2500HD CTD
Old 12-06-2016, 07:52 PM   #94
KenHwy61's Avatar
New favorite mod
Living in Minnesota I use the I use the fireplace a lot and usually as the main source of heat. I am impressed something about the same wattage as a hair dryer can keep the camper warm even with temps near freezing. The thing I don't like is the generic on-off control that keeps the camper temp constantly fluctuating between 66 and 76. To address that I installed a Watlow proportional controller. Now when I switch on the fireplace the fan stays running and power to the heating element is now pulsed by the controller. This results in the fan providing a constant pleasant white noise and perfect temp control that stays exactly where you set it.
Name:	av watlow.jpg
2012 Ram 2500HD CTD
Old 12-07-2016, 08:38 PM   #95
tahkeyla's Avatar
Our mods
Hi, we have had our new acquisition for about 2 weeks now. It's totally unique. We previously had a 32' Rockwood, 2006. We decided to upgrade,and looked at new ones, and the quality and fit and finish on the "brand" names was questionable at best. Then we found this one on the internet, even though its used lightly, its features and quality are way up there. Even then we had little things that we had to address, the first was setting up the Sat system, it is HD PVR, so we had to turn the incoming cable line in to a sat line, the PVR require 2 incoming cable from the dish. Then we ran a HDMI line from the sat receiver down from above the tv, behind the fireplace into the belly and back up under the kitchen sink, then to the outside tv. Hd sat outside then, a bit of work for sure but worth it. We took the 32" tv and put it outside, and were able to fit a 50" above the fireplace, again a bit of work, but awesome. And yesterday my crafty wife tackled the front window curtains, we installed a lower curtain rod with rollers and she made up the new curtains, they look 100% better than the saggy dark ones that were there. A few other little things to do, but looking forward to spring so we can check it out, gonna be a long winter.
2013 Aviator Wright Flyer 1915
2014 Ram 2500 Cummins long box
2013 Hyundai Veloster turbo
2011 Polaris RZR 800 (will fit in long box)
ID:	126362   Click image for larger version
ID:	126363   Click image for larger version
ID:	126364   Click image for larger version
ID:	126365   Click image for larger version
tahkeyla is offline   Reply With Quote
Old 12-14-2016, 09:48 PM   #96
The curtain mod was one of the first we made. Our cats sleep between the curtains and window like they were in a hammock. It's either there or in bed with us and I'm not happy with critters walking around on my bed while I sleep.
Our fireplace has a 2 Degree on/off setting and never varies more than that. It will set to leave the fan on with/without heat just like the main thermostat's fan on/auto setting.
Old 12-25-2016, 07:43 PM   #97
KenHwy61's Avatar
I know I am way behind in Blackhat6mike in doing these mods but I finally got them done. There is some wasted space in the Aviator in the bedroom and above the microwave. I made hinged panels and now have substantial extra storage above the bedroom tv and a pretty good sized kitchen storage area over microwave. Not sure what mod is next but I am sure something will come to mind!
Name:	Aviator linen closet.jpg
ID:	127069   Click image for larger version
Name:	av over micro.jpg
2012 Ram 2500HD CTD
Old 12-27-2016, 07:05 AM   #98
tahkeyla's Avatar
Hey hi. I noticed on one of your earlier mod posts that you had the outside entry handle lighted. If it's not a secret how did you manage to do that ? Thanks
Old 12-27-2016, 07:42 AM   #99
KenHwy61's Avatar
It's no secret and pretty easy to do. I ordered 2 led rv grab handle lights from Amazon. They are made just for this purpose. I then siliconed them in to the handle ends and wired them to a switch on the control panel just inside the door. When I first removed the handles I found they were full of water from poor factory sealing so I drilled small drain holes and resealed it up good with clear silicon.
2012 Ram 2500HD CTD
Old 12-27-2016, 06:42 PM   #100
Odd that this subject came up. Two weeks ago while I was getting the "Bomber" ready for our annual Christmas trip to the FL Keys, I was leaving the unit and as usual, grabbed the plastic handle at the door while stepping down. As soon as I went for the second step, the handle snapped into right in the middle, which left me on my left side in the grass. I'm too old to take this kind of shock! Didn't break anything but the handle.
Never in a million years would I have believed that handle could break. As soon as we get home, a SS tube will replace the plastic handle. Can't imagine what damage would have been done if it had happened to my wife. A scary thought!
I'll post a picture when we return.
modifications
