Old 04-09-2019, 08:18 PM   #161
KenHwy61's Avatar
Chris, Welcome to the Aviator family! You did get a good buy on that unit. You would think if the dealer went through the work of replacing the laminate they would have at least used a similar wood colored sheeting. Maybe the grey was what they had around. Post up pictures of your improvements. It always interesting to see how people customize their campers.
Aviator Wright-Flyer#1908
1996 Holiday Rambler
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 04-09-2019, 09:10 PM   #162
The laminate surface pealed loose.... Didn't know that was even possible, but it's good to know. Must have been extra humid in there for awhile.
saltsman is offline   Reply With Quote
Old 11-16-2019, 07:15 PM   #163
AWF 1957
dshome's Avatar
Aviator pass through sliding tray
The following photos are of a tray I assembled to slide either direction. The tray rides on HDPE (high density polyethylene) or cutting board strips. The top is held down by the quarter round so it does not tip up when extended. I have a material list with dimensions somewhere and will add it later. The sterilite containers fit snugly and pass through the opening without touching. The side rails are screwed down through the bottom rail with additional "El" brackets for support. All wood to wood surfaces were glued and screwed.
AWF #1957
dshome is offline   Reply With Quote
Old 11-16-2019, 08:05 PM   #164
AWF 1957
dshome's Avatar
Aviator mods
Replaced the louvered vent above the tv with a photo. On hinges to reveal added storage space for towels or linens.
Added better faucet and more towel rack space in bath
Replaced plastic heat registers with metal closing type
Replaced plastic back splash above stove with metallic tiles
Added battery cutoff switches
ID:	219283   Click image for larger version
ID:	219284   Click image for larger version
ID:	219285   Click image for larger version
ID:	219286   Click image for larger version
AWF #1957
Old 11-17-2019, 06:11 PM   #165
KenHwy61's Avatar
Nice work on the mods! I am glad you were able to post them. It always interesting to see what other owners do and a good way to get new ideas. Hard to believe it has already been six years since the Aviator was produced. They seem to be holding up well although I did have my Domectic refrigerator fail earlier this year. That is quite a project to replace. The hallway is not wide enough to move the refrigerator in either direction. Since moving the kitchen was out of the question, I had to take out the bathroom door assembly, cut out the bedroom door frame, and take it out the back door!
2012 Ram 2500HD CTD
modifications
