Old 05-31-2015, 04:26 PM   #11
KenHwy61's Avatar
Unfortunately, I now have a pretty bad leak in my fresh water tank and have opened up the underbelly to drain out the gallons of water. I will soon pull the tank to see where it is leaking. You can see the water dripping very steadily off the metal frame and running to low points. As long as the belly was open I thought I would show where I bolted the table down where as originally wood screws were all that held a very top heavy table in place.
Does anyone have a good contact within Forest River? I am hoping that although my Aviator is 2 months out of warranty they will in good faith send me a replacement tank which I will install myself. Any thoughts?
ID:	78631   Click image for larger version
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is online now   Reply With Quote
Old 06-01-2015, 10:08 PM   #12
KenHwy61's Avatar
I lowered the water tank today. It turns out I poked a hole in it when drilling holes for the table bolt mod I did last fall! Oh well, fixed the leak and put it back together. Also finished installing a wind deflector to keep bugs off the glass. Got it on craigslist and modified it to go on the back of my topper. It weighs only a few pounds and installs in less than a minute. I definitely recommend a 50 to 15 amp adapter. It is very convenient for at home or a quick overnight stop when you don't want to wrestle with python power cord.
Name:	av wind deflector.jpg
ID:	78788   Click image for larger version
2012 Ram 2500HD CTD
Old 07-16-2015, 10:04 PM   #13
KenHwy61's Avatar
Got a couple new things to post. First of is Blackhat6mike's digital refrigerator thermometer. Handy to keep an eye on things without opening the door. Maybe he will share where he got it and it installed. The second thing is for whatever reason, the Aviators did not come with a screen door so my wife helped me make one. We used a modified Magic Screen and a curtain rod. it just slides out the way when not in use. We are very please with how it turned out and how well it works.
Name:	eddies ref therm.jpg
ID:	83121   Click image for larger version
ID:	83122   Click image for larger version
ID:	83123   Click image for larger version
2012 Ram 2500HD CTD
Old 07-22-2015, 08:31 AM   #14
BamaCamper
cjearle2's Avatar
Wow, you two have been busy. Looking forward to working on my Aviator now that we have it back. Going to do something with my backsplash and I really don't like my curtains. Great idea guys.
Aviator Wright Flyer 1912
F-250 2014
cjearle2 is offline   Reply With Quote
Old 09-28-2015, 10:17 PM   #15
KenHwy61's Avatar
unusual mod
Aviator #1916 is for sale in Arizona. It is interesting to note the power tongue jack has been moved back a few feet and is now under the hood. I'm not sure why you would do this except to maybe keep it out of the elements. Any other ideas?
Name:	av under hood jack.jpg
ID:	90171   Click image for larger version
Name:	under hood jack.jpg
2012 Ram 2500HD CTD
Old 09-30-2015, 09:59 PM   #16
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Soooo...you have to raise the hood to lower the tongue jack?? What a PIA that must be.
The dual temp gauge I installed in the control panel of the frig/freezer can be bought for $10 on Amazon. It has two temp probes with about 3 ft wire each. I put one in the freezer and one in the fridge. It flips back and forth between the two every 2-3 seconds. Easy install, just cut a rectangular hole in the plastic and mount it flush. I added a micro-mini toggle switch beside it to turn it off/on.
Oh yes, I used white Gorilla tape to secure the probes and lead wires. You don't even see them.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 10-01-2015, 09:15 PM   #17
Maybe it was moved back so he could lower his tailgate without unhooking. I can't lower mine with unit attached. I've thought about moving mine back, but not that far. Not sure if you can open the hood if you move it back at all. I'll have to check it.
Old 10-06-2015, 09:54 PM   #18
BamaCamper
cjearle2's Avatar
We actually got our tail gate stuck on the power button of our jack. A fellow camper had to come over and help us get it unstuck. Would like to move ours back as well.
F-250 2014
Old 10-07-2015, 10:49 PM   #19
KenHwy61's Avatar
Thanks for making the FB page Carol! My tailgate wouldn't fully open with my previous travel trailer either. I think it is a common situation. I think you could move the jack back slightly and the hood would still clear.
Since we watch tv inside, I removed the outside tv and turned the compartment into a campfire kit complete with wienie roasters, cooking irons and a light.
In the utility cabinet I made a few changes as well. I removed the filter and instead use an inline filter outside. I put metal water shut-off valves on the water heater, fresh and city water supply lines. I mounted the pump in a plastic tub in case of leaks.
Blackhatmike and I just finished going through our tv/video systems and adding input switches. I think we have a pretty good idea of how it all works so if anybody has any questions feel free to ask.
ID:	90981   Click image for larger version
Name:	utility closet.jpg
2012 Ram 2500HD CTD
Old 10-07-2015, 11:27 PM   #20
BamaCamper
cjearle2's Avatar
You two are like the Tim the tool Man! I can not wait to get ours back so we can work on it.
F-250 2014
modifications
