Old 11-28-2015, 07:57 PM   #31
KenHwy61's Avatar
I kept the fill port up front and ran an equalizing line between the two tanks with the pump line in the middle so they will fill evenly. I weighed my tongue at 1340 with 2 batts and full propane but no water. I figured now the rear tank will counter-balance the front when I fill.
With two more solar panels and a new 60 amp controller you are going to be making so much power you can sell the extra back to your local electric utility!
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 11-29-2015, 08:15 PM   #32
KenHwy61's Avatar
Winter project
Sorry to keep boring all the forum non-Aviator members, but I'm back at the underbelly makeover again! Now that the new second water tank is in and the electric wiring is all cleaned up, I am starting on the duct work. The Aviator Wright Flyer has four outlets from the furnace. One to the rear bedroom, one to the bath, and two run to the front living room. In typical RV fashion, the two flexible living room ducts were pushed through a space really only big enough for one crushing and tearing open one of the ducts. To solve this problem I ran one duct to the front passing through the first vent and on to the second. I am putting adjustable type vent registers to control the air flow between the two. That leaves me with an unused flexible duct to which I plan to add a damper and control it with a cable in the utility closet. This will allow me to heat the underbelly only as needed. The photo is a close up of the Aviator floor taken where I removed a floor vent. It is 2 inches thick and made of a composite material sandwiched between two layers of fiberglass.
Name:	close up floor.jpg
2012 Ram 2500HD CTD
Old 11-30-2015, 06:00 PM   #33
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
That composite floor is worth it's weight in gold as it's not affected by water and it's really strong. Judging from the flimsiness of the heater ducting, I figure there is some restriction in the path somewhere. Would like to replace it with thin walled PVC, but haven't looked to see if there is an acceptable path for it to the vents. Even if some of it can be replaced, that would make a big difference in the air flow and retention of heat. I converted our sailboats ducting with 4' PVC and it made a huge airflow increase.
Went fishing today. I think they heard me coming!
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 11-30-2015, 08:25 PM   #34
KenHwy61's Avatar
You could run PVC ducting. I gave it some thought but have to draw the line somewhere. Besides I hardly ever run the furnace, just once in a while to burn out the cobwebs! The trailer is very well insulated and the electric fireplace alone is enough to keep it at least 40 degrees above ambient. I spent 3 days in 20-30s temps with no problem. On the sunny southern shore where you live the furnace just takes up space!
2012 Ram 2500HD CTD
Old 11-30-2015, 08:39 PM   #35
The only time I've cranked up the furnace was to see if it worked. It didn't! The distribution box was missing two covers. Yep, quality control!
The insulation is so good, we also just use the fireplace to heat. Does the job just fine.
As far as the PVC upgrade in the venting, it's just one of those things to make mo better.
Old 11-30-2015, 09:51 PM   #36
KenHwy61's Avatar
Sometimes I think we are the only two Aviator's owners around! I must say my wife and I do enjoy having the only Wright-Flyer probably in the entire Midwest. I've never seen another anywhere, not even on the highway. When I'm done underneath I'm seriously thinking about insulating between the back wall and rear cap. A quiet bedroom is the key to happy camping! That would be a lot of cans of foam but I'm leery of using fiberglass batts because if they happen to get wet they tend to stay wet and mice don't seem to mind nesting in it. Have you done any more thinking on this?
2012 Ram 2500HD CTD
Old 12-05-2015, 09:04 AM   #37
KenHwy61's Avatar
Winter project
With fairly warm weather my winter project continues. I have been posting pictures as I go to document how the Aviator is put together. The ductwork redo is now complete. To finish, I replaced the original generic plastic floor registers. I found some that have scroll work that match the window valances. I painted them "oil rubbed bronze" to match the cabinet hardware to tie it all together. Also is a photo of the short circuit protector for stabilizer jacks. There is one in the front and one in the rear attached to the bottom of the floor above where the jacks are located.
ID:	95613   Click image for larger version
ID:	95614   Click image for larger version
ID:	95615   Click image for larger version
2012 Ram 2500HD CTD
Old 12-05-2015, 04:14 PM   #38
Wright Flyer
As much time as you have spent under the Aviator, you would have saved time by just turning it over to work on it. Crawling around on the ground is not an activity I enjoy.
The vents look cool! Where did you get them? Since we don't use the furnace, I just put brown Gorilla tape over them to keep the trash out. Installing closable vents is now on the list.
I installed 14 cans of open core foam into the rear cap area via the wall plugs in the cubbies beside the bed. No idea how much of the area I filled as I can no longer get my snake camera into the area. For all I know it may be all piled up in the underbelly below the end cap. I put several cans into the upper position light sockets over the back window and there is still room there for more.
Headed for Lanier Islands in N. GA Wed for a week, then down to Jolly Roger RV Park on Marathon Key, FL from Dec 23-Jan 1. We got the last spot available. Expensive!! But warm and on the water. [our only two requirements]
Old 12-05-2015, 07:50 PM   #39
KenHwy61's Avatar
Winter project
Turning it over would have made things much easier! Spent most of the day under it today. Just about all done and its a good thing because I've about had enough of crawling around! I will wait until spring to put the belly cover on because I want to check for water leaks. I am pretty confident everything will be good for a very long time and I also like the fact I found no real design flaws and the camper is structurally very well built. I got the vents from a local home center and am real pleased with how they look. Makes a big difference for very little money.You might be able to take out a rear upper clearance light and look down with your scope to see how the foaming went. I am very jealous of your upcoming trip. Sounds great!
2012 Ram 2500HD CTD
Old 12-05-2015, 09:47 PM   #40
I'll send pix. Lake Lanier first, then Gulf of Mex later. Got a feeling LL is going to be cold...by my standards. DW will be attending a continuing ED class for her real estate teaching license at the convention center there on Lanier Island.
modifications
