Old 03-09-2016, 08:39 PM   #71
BamaCamper
cjearle2's Avatar
Originally Posted by KenHwy61 View Post
I'm glad the rest seems good. If you have any other issues let me know. I have taken most of my Aviator apart so I know pretty well where everything is and how it was put together on the Wright-Flyers. One thing to look for is it has been common for water to leak from behind the dump valve/flush compartment and appear on the bathroom floor. Not too hard to fix though. I would love to make it to Goshen but not being retired it is hard to get enough time off to get there. Someday I hope meet up with you and other owners maybe somewhere in the Florida panhandle area. Spending most of our summer days off on our site on lake Superior. Beat the heat this summer and come on up!
Grand Marais Camping Marina RV on Lake Superior
We will have to try and plan to come up there. Never ever been that way.
cjearle2 is offline   Reply With Quote
Old 03-09-2016, 09:19 PM   #72
KenHwy61's Avatar
Lots to see along the north shore of lake Superior. Lighthouses and scenic state parks. Best weather is July-August with highs in the 70s but also the most crowded time as well.
Tall ShipsŪ Duluth 2016
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 03-09-2016, 09:27 PM   #73
BamaCamper
cjearle2's Avatar
I will do some research on it and talk with Jim. See if we can plan a trip up there this summer.
Aviator Wright Flyer 1912
F-250 2014
Old 03-09-2016, 09:45 PM   #74
KenHwy61's Avatar
That sounds good. Someday we will get an Aviator group rally figured out. Got so many places I want to visit but work keeps getting in the way!
2012 Ram 2500HD CTD
Old 03-13-2016, 10:36 PM   #75
KenHwy61's Avatar
Bedroom speaker mod
I have a hard time hearing the bedroom tv especially if the Maxx fan or a/c is running. So while I have the bottom underbelly cover off I ran RCA cables down from the tv, under the camper and up between the back wall and the fiberglass rear cap. I hooked that to a small amp and a pair of 3 1/2 inch speakers that I mounted in the bedside cubbies. I also added a 12V USB charging outlet to make phone charging easier when boondocking. Just a FYI for Aviator owners: the rear wall is made of approx. 2 1/2" thick slab Styrofoam sandwiched between two layers of Azdel and then covered by the fiberglass rear cap.
Name:	bedroom speakers.jpg
2012 Ram 2500HD CTD
Old 03-13-2016, 11:02 PM   #76
BamaCamper
cjearle2's Avatar
You are tricking your Aviator out. Nice work!
F-250 2014
Old 04-02-2016, 09:49 AM   #77
BamaCamper
cjearle2's Avatar
Ken,
We tried to straighten out the hinge on the Aviator front door. Using a block of wood and hammer. It would not budge . The top hinge is bent inward, and the door is out of alignment
Believe that is why our door kept flying open going down the road. Until we get it Back to Goshen guess we will have to grind out the door latch so we can dead bolt the door.
F-250 2014
Old 04-02-2016, 11:43 AM   #78
KenHwy61's Avatar
Sorry to hear the hinge wouldn't budge. You might have to heat it up to bend it or drill out the rivets out and just replace it. The downside is both require tools you may not have so grinding out the latch area maybe your easier solution. Hopefully everything else is looking good.
2012 Ram 2500HD CTD
Old 04-16-2016, 03:30 PM   #79
KenHwy61's Avatar
Winter project finished!
At the beginning of this winter I decided to add a second fresh water tank giving me a total capacity of 100 gallons. While I had the bottom off I improved on the factory wiring, ductwork and plumbing. I also insulated the parimeter and large voids in the front and rear with R26 insulation. To keep it from freezing, I added a heating system that blows warm air from the cabin to the basement as needed. While it was cold outside I verified all four tank heaters were operational. To finish it all up I installed new insulated Coroplast panels in easy to remove four foot sections. We are now enjoy our Aviator for a 3-day weekend on beautiful lake Superior. I posted a picture of our view out the front windows.
Name:	lake superior window view.jpg
2012 Ram 2500HD CTD
Old 04-17-2016, 03:25 PM   #80
BamaCamper
cjearle2's Avatar
That is beautiful!
As far as adding the second water tank, will that make it extra heavy? These Aviators are tongue heavy as it is.
F-250 2014
modifications
