Old 08-18-2015, 08:22 PM   #21
Blackhat6mike's Avatar
FYI. Anyone with a Carefree Freedom Freestyle awning needs to carry a 3/8 drive ratchet wrench with them to retract the awning when it fails...and it will. The wrench is inserted inside a removable round plug on the front cap of the awning and cranked in. An 18 inch long zip tie or piece of line that long to secure it in the closed position after it is retracted.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 08-18-2015, 08:32 PM   #22
KenHwy61's Avatar
Thanks for the tip. I will be sure to have a ratchet available. Love the convenience, the aluminum case and the auto retract feature of the awning but wish they didn't seem so fragile. It would be hard though to go back to the old manual style. Too spoiled now!
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 08-19-2015, 11:15 PM   #23
snowtosurf's Avatar
Hi Everyone, we will be applying the tests, for the awning's motor, in this guide http://www.e-carefree.com/documentat...e%20Manual.pdf
This may help anyone else with the non-operational awning issue.
snowtosurf is offline   Reply With Quote
Old 08-19-2015, 11:16 PM   #24
snowtosurf's Avatar
Old 08-24-2015, 12:09 PM   #25
BamaCamper
cjearle2's Avatar
Originally Posted by rmtaya View Post
Anyone know the part number of an aviator wright flyer awning my motor went out and needed to be replace? Is it better to replace the whole awning or replace the motor? Any advise all new to this. Thank you. Camping World St. George Utah want to much for it.
We are on our third motor from Carefree. There is a 800 number to call carefree. You can get the model number off your awning. There should be a label on the old motor or on your casing. Carefree is now replacing our entire awning. The mounting brackets broke on it as well and found out it was not mounted correctly from the last dealer that did work on it. It was a severe road hazard.YIKES! In fact it was falling off at the Rally. We were inside the camper head a bop sound and looked out saw the awning drifting down. Had to go out the rear door and hold it up until the workers go there to secure it. Evidently the free standing arms are a lot of drag on the motor.
Aviator Wright Flyer 1912
F-250 2014
cjearle2 is offline   Reply With Quote
Old 08-24-2015, 12:14 PM   #26
BamaCamper
cjearle2's Avatar
Originally Posted by snowtosurf View Post
Hey Blackhat6mike it seems that within a week of reading this thread (all the while thinking my awning has been performing perfectly) my awning dies. It rolled itself back in never to wake up again. Fuse is fine so it must be the dreaded dead motor. I can't find mention of model name or number in any info we have with Aviator. Do you remember what to tell Carefree to order the part/s?
Ours went out and we called them. Our went out with it extended and was trying to get home before the storm. The tech at the 800 Number walked us thru and how to find the model and serial numbers. Like I said previously we are on our third motor. Now having the whole Awning replaced. Good Luck
F-250 2014
Old 08-24-2015, 12:31 PM   #27
KenHwy61's Avatar
I didn't realize you were on your third motor. The dealer gave me the impression after mine failed during my PDI that only the initial factory motors were defective. The replacement motors were supposed to be good. Did you learn something new at the rally and is that why Forest River is replacing your entire awning?
2012 Ram 2500HD CTD
Old 08-24-2015, 02:36 PM   #28
Carefree Freedom Freestyle Electric Awning
Snowtosurf and all.
The part number in the parts list and the part number literally ON THE MOTOR are not the same. I sent Snowtosurf the number directly off the motor before I looked at the parts list in the owners manual. The one in the manual is R001712XXX. Don't even ask!!!!
The date of manufacture on my new motor is June, 2015. I don't see a DOM on my old motor. It was my "case connector" where the weld broke. I'm saving it as I believe the party isn't over yet. I welded it back up with three passes so it will never break again.
awning
