Old 08-22-2014, 02:08 PM   #11
Boat Builder
Correct - the swing out tube is for storage.
At the other end is a little flex pipe...slide that back to expose the bayonet fitting coming from the trailer.
Sea-Born is offline   Reply With Quote
Old 08-22-2014, 02:12 PM   #12
Naviator's Avatar
Ah hah!! Well thank you Sea-Born. That makes sense and I can stop looking for an adapter that doesn't exist:-)
2013 Aviator Electra 1939
2013 Aviator Wright Flyer 1949
2007 Chevy Express 2500 Duramax
Naviator is offline   Reply With Quote
Old 08-22-2014, 02:18 PM   #13
VinceU's Avatar
I would buy a 4-6' length of ABS pipe and two fittings and do it right.
Old 08-22-2014, 02:27 PM   #14
Boat Builder
That will not work...the other end of the storage tube is not sealed to the sewer outlet...you will be flushing to the ground.
The terminal under the trailer is standard 3" bayonet fitting.
Old 08-22-2014, 02:35 PM   #15
Originally Posted by Naviator View Post
So we bought the flexible sewer hook up pipe but it doesn't have anything to hook it up to on the hard pipe of the unit. Is it missing something?
Attachment 61143
This is a PIC. of a storage tube. Youroo!!
Old 08-23-2014, 01:02 PM   #16
Naviator's Avatar
I have already been made aware of that fact, but thank you for your reassurance :-)
Old 08-25-2014, 01:07 PM   #17
BamaCamper
cjearle2's Avatar
In ours the swing out is storage for your hose. You have to one time crawl underneath the camper and hook up your sewer hose after you feed it thru the swing out tube. Then when you need it screw off the cap and pull your hose out and connect to drain.
Aviator Wright Flyer 1912
F-250 2014
cjearle2 is offline   Reply With Quote
Old 10-16-2014, 08:14 AM   #18
alkemy's Avatar
So I have to crawl up under the trailer to connect the flex pipe? This is also my first RV and wasn't briefed on how to hook it up. The owners manual that I down loaded doesn't show me how to hook it up either.
You have to crawl under just one time to hook it up after that you just pull it out each time. This is the storage for your flex pipe. You will have to pull the rubber pip down and then you will see the cap that will need to be removed so that you can hook your flex pip up to thru the storage pipe. Its real simple to do and is a nice feature. Good like
alkemy is offline   Reply With Quote
Old 10-17-2014, 12:38 PM   #19
Naviator's Avatar
Thanks everyone for all the input. Works just as it was explained on here:-)
Old 12-02-2014, 09:32 PM   #20
Rivnut
Rivnut's Avatar
DID you get an answer to the SD card question or the sewer question??
Rivnut
Rivnut is offline   Reply With Quote
