Old 01-20-2019, 08:46 PM   #1
busguy's Avatar
Weight distribution hitch
What hitch is everyone using. Trying to figure out what works with the aviators is since it has to clear the hood
busguy is offline   Reply With Quote
Old 01-26-2019, 08:13 PM   #2
busguy's Avatar
Wtf is nobody seeing this post or am I being ignored.
Old 01-26-2019, 08:35 PM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
Did you do a search? This is kind of beat to death and tons of info already out there. For instance.....
Weight Distribution Hitch for first timer
It's going to come down to if you want to spend a ton on a Hensley or not.
05CrewDually is offline   Reply With Quote
Old 01-26-2019, 08:36 PM   #4
Multi-Slacker
What are you pulling with and what will you pull? Don't understand the clearance issue.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is offline   Reply With Quote
Old 01-26-2019, 08:37 PM   #5
Weight Distribution Hitch for first timer - Forest River Forums
X2
TV - 2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Drinks of choice: woodford reserve, knob creek & any great bourbon-just about any of San Diegoís craft beer and Pabst Blue Ribbon
Beachbourbon is offline   Reply With Quote
Old 01-27-2019, 07:03 AM   #6
busguy's Avatar
The front hood has to clear or I can't access the propane tanksClick image for larger version
Old 01-27-2019, 08:04 AM   #7
busguy's Avatar
My question was related to the Aviator which is unique. Just wondering what other Aviator owners use that's all. I have had RVs for twenty years so not new to this but new to the Aviator.
Old 01-27-2019, 08:49 AM   #8
GOODBYE SUIT - HELLO RV!!
Change your title :)
I think a lot of us ignored the post because WDH is discussed ad nauseam and easy to search. Since you are asking Aviator specific (which, I have to admit I overlooked when I read your post because the A was not capitalized so I thought it was a typo) you need to put Aviator RV WDH Suggestion in the title of your thread.
And shame on your for the "wtf" post.... you needed to do a better job asking the question
HAPPIEST WHEN CAMPING!
2019 Rockwood 2104s ****
2017 Starcraft Satellite 16KS
2012 Jayco X23B Hybrid
2009 R-Vision C243S Hybrid
2006 Coleman Bayside PUP
HappyCamper1962 is offline   Reply With Quote
Old 01-27-2019, 09:25 AM   #9
KenHwy61's Avatar
I use a basic Reese WDH I bought in 1998. It is rated for 12,000. There is very little extra clearance when opening the hood but it works good for me. The hood is slightly adjustable and the bottom edge may need to be trimmed depending on what you buy. You can try looking up the Aviator owner named Rsracing1. He just bought a Wright Flyer and a new hitch. Send him a private message and ask what he bought. Let me know if have more questions and I will try to find the answer.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 01-27-2019, 09:43 AM   #10
KenHwy61's Avatar
Sorry, I just noticed the picture you posted. I am assuming you have a hitch, don't want to buy a new one and can't get the hood open with it installed. Try playing around with hood mechanisms. See what you might be able to adjust. I ended up removing the left opening gas strut and replacing it with a prop rod. It still opens with little effort but may give you enough extra clearance and allow you to guide it by hand up over your hitch. It also makes the hood much easier to close but also means it will not stay open without a prop rod.
2012 Ram 2500HD CTD
Old 01-27-2019, 10:26 AM   #11
Chuck_S's Avatar
Glad you posted a photo and clarified the Aviator is a trailer. I was wondering why there'd be hood clearance issues since the hood is at the other end of an Aviator.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 01-27-2019, 11:49 AM   #12
busguy's Avatar
Thanks. The hitch I have on it is temporarily borrowed. I am considering the Blue Ox because it is about as low profile as I can find for clearance
Old 01-27-2019, 11:56 AM   #13
Grammar Pedant
67L48's Avatar
Listen! Are you a-holes going to help me or what!?
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 01-28-2019, 12:21 AM   #14
I think I'm using a Equal-i-zer from Progress Mfg., which is a nice hitch - however it took some modification with a saw to remove some to the height to help the Aviator's hood function properly. As you noticed, the hitch needs to be low profile and/or have a shorter arm.
saltsman is offline   Reply With Quote
Old 01-28-2019, 01:14 AM   #15
SailorSam20500's Avatar
Hmmm. More expensive solution. I think the Propride hitches are the best at sway control. They offer a strap setup to hold the WD bars that in the picture on the website is VERY low profile. It might work. Give Sean, the owner a call and talk to him about your issue. He is VERY helpful.
https://www.propridehitch.com/lipper...echnology-kit/
You might be able to use the strap tek on other hitch brands. Good luck.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 01-28-2019, 08:10 AM   #16
busguy's Avatar
Thanks for all the input. I apologize for my initial post, my cop attitude came out for a minute there. I did get attention though....some good some not so much. I'll take it like a champ.
Old 01-28-2019, 08:47 AM   #17
busguy's Avatar
Wow! That Propride is very expensive.
Old 01-28-2019, 09:15 AM   #18
Chuck_S's Avatar
My recommendation matches Saltman's.
Once the Equalizer (tm) is mounted and adjusted properly it can be welded to the trailer frame if wanted although just cutting off the parts of the adjustable bracket that stick above the frame works as well. Other than the adjustable bracket everything is below the top of the trailer frame.
-- Chuck
Old 04-09-2019, 02:52 PM   #19
Just found a bolt on chain hook that eliminates the supplied straddle device. You bolt it to the side of the trailer. It completely eliminates the interference with the hood.
That's my story and i am sticking to it.
Chris hill is offline   Reply With Quote
Old 04-10-2019, 10:34 AM   #20
busguy's Avatar
That is exactly what I got and it works perfectly. Thank you everyone for the input
hitch, weight, weight distribution hitch
