Old 06-19-2014, 08:54 AM   #1
JerseyGuy's Avatar
12 Volt Plug Fuse
Does anyone know which fuse controls the passenger side dash plug? I overloaded it with a plug in inverter and I can't find out which fuse to replace. The inverter works of the driver side plug as well as the one over the pantry.
JerseyGuy is offline   Reply With Quote
Old 06-19-2014, 10:18 AM   #2
StephanFR3's Avatar
I would look in line is on wire under dash. Trace wire. Or under hood or engine fuse box. 2nd not as likely due to other dash receptacle working.
StephanFR3 is offline   Reply With Quote
Old 06-21-2014, 06:48 AM   #3
did you find the fuse ??
svwc is offline   Reply With Quote
Old 06-21-2014, 10:49 AM   #4
JerseyGuy's Avatar
Not yet. It's a tight squeeze to get to the fuse box so I was hoping someone knew which one to replace. Otherwise I will check with Ford when I have the MH in for work next week.
Old 06-22-2014, 08:18 AM   #5
Online_17's Avatar
I checked the electrical drawings on my 30DS. In the Fuse Brain Box underneath, above the batteries, there is a 15A fuse labelled, " AUX- Disconnect Power ( to Dash) . You could try that one? From left to right, it's the 4th slot, labelled blue. Careful to disconnect battery before opening box. Otherwise, check AC 110 breakers and long stretch, Fuse 1 in bedroom panel as it is labeled "Road Side Forward" . It's the only one I have no idea what it for, lol
I know this isn't the best time to ask, but how did you hook an Inverter to those two plugs? CW is adding a pure sine 2000w to my FR3 but said I would need to run an extension cord to it....doesn't sound appealing.
Online_17 is offline   Reply With Quote
Old 06-23-2014, 11:55 AM   #6
FR3 Division
Michael Hums's Avatar
The outlets in the dash are on a 20A main circuit but can only handle 8A so there is a inline fuse just behind each outlet on the dash panel. If you need further assistance call 574-206-7600 and the Parts/Service/Warranty guys can get you the documentation you may need to finish trouble shooting your electrical.
Michael Hums is offline   Reply With Quote
Old 06-23-2014, 12:36 PM   #7
JerseyGuy's Avatar
Name:	ImageUploadedByForest River Forums1403544931.103600.jpg
ID:	56158 I'm talking about the auxiliary plug to the right of the temperature controls. Does that help?
Old 07-11-2014, 10:45 PM   #8
I have blown the 12 volt fuses while charging my iphones and trying to run a cigarette lighter style hand vacuum. Don't bother trying to fit in that little space under the steering wheel and check in the fuse panel. After checking every fuse and having a red face from hanging upside down, I checked directly behind the lighter. There are wires running directly behind each 12 volt on the dash that have separate fuses. They are 5 amp fuses that you can replace. Better keep a stock of them! Very frustrating. The dealer said not to put a higher amp because it could cause a fire and it wouldn't be covered by warranty.
FR3Jones is offline   Reply With Quote
Old 07-12-2014, 04:59 AM   #9
JerseyGuy's Avatar
Went through the same upside down routine. Mine are 7.5 amp. I replaced it with the same size.
FR3 30DS In New Jersey
12 volt, fuse
