Old 06-11-2016, 08:28 AM   #1
wayne and sherry's Avatar
12 volt plug in. Dash right side.
I must of blew a fuse. Right side 12 volt plug in not working. Any help out there as to where the fuse is located?Click image for larger version
Name:	ImageUploadedByForest River Forums1465651694.698750.jpg
wayne and sherry is offline   Reply With Quote
Old 06-11-2016, 08:46 AM   #2
Found it eh!!
Old 06-11-2016, 04:54 PM   #3
where was it, as a fyi
Combatcoal is offline   Reply With Quote
Old 06-11-2016, 07:06 PM   #4
Right on. Drop down on your back eh, and look up under the dash and see the wire on the back side of the out let. Just grab that wire and pull it out. You will see a flat fuse 7.5. Now l know a person should never ever put in a bigger fuse but please understand I'm kind of a rebel and stuck in a 10.0. Mostly cuz that's all l had...
Old 06-11-2016, 07:07 PM   #5
Old 06-11-2016, 07:44 PM   #6
u rebel u......👍
Old 06-12-2016, 03:04 PM   #7
Happy New Member
I have 4 outlets in my new 2016 rig, only 2 work! Is their only 1 wire to each to remove and find this "fuse" or does each outlet have 2 wires? If 2 wires, which do you remove to locate this fuse?
Thanks.
GoBoy is offline   Reply With Quote
Old 06-12-2016, 09:26 PM   #8
What 2 are working and where are they located?
What 2 are not working and where are they located..
Old 06-13-2016, 09:07 PM   #9
Happy New Member
12 Volt Plug in Dash
1 12 volt plug in dash not working and the plug in the "Glove Box" is not working! The other plug on the dash is working fine and the plug located in a cabinet near the TV is working well also.
GoBoy
Old 06-14-2016, 06:12 AM   #10
GoBoy
Look under the dash under the outlet that isn't working. Locate the wires leading to the non working outlet and see if a flat fuse is in line. If so replace it and see if you have restored power eh.
12 volt
