Old 04-10-2015, 11:53 AM   #31
Could someone explain what that percentage represents? Would a 50% grade be equal to half of 90 degrees, 45 degrees from level?
J W Bowman is offline   Reply With Quote
Old 04-10-2015, 12:08 PM   #32
100 ft horizontal travel and 100 ft vertical travel would be a 45 angle = 100% grade and you would have actually traveled ~141ft.
50% grade would be 22.5 angle.
Old 04-10-2015, 12:08 PM   #33
I went up a place called the Sonora pass in California. They did not advise that it was a 28% grade 1/2 way up. With a 40' 5th wheel I could not turn around when I found out so up I went. It all depends on your truck and how many switchbacks it has. I have a f350 dully and surprisingly enough I had no trouble going up. It was 7 miles that my nerves to a beating on but it can be done with the correct truck.
j free is offline   Reply With Quote
Old 04-10-2015, 12:09 PM   #34
Fulltime family RVer
Originally Posted by glen1971 View Post
If things didn't go sideways burning up a tank of fuel going up, you'd want to make sure you changed what's left of your brakes at the bottom...
I think passing on this one is the right call..
Originally Posted by fdp View Post
Getting up the grade is half the problem. When your coming down a grade your need to be able to control your speed and stop.
I get that this is an insane grade, but I feel like it wouldn't be awful since it is only a mile. BUT- I'm still a newbie and don't have a ton of experience.
Old 04-10-2015, 12:58 PM   #35
A situation like this is where torque would be your best friend. If I had a NA gas engine, I'd want a seriously low first gear so I could rev without moving very fast. So, what type of gearing do these things have???
Old 04-10-2015, 01:05 PM   #36
R&J Silverback's Avatar
HOLLY CRAP IS RIGHT!!!!!I I would have to back up the road hope it doesn't have switch backs
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 04-10-2015, 01:28 PM   #37
CAT-RN's Avatar
25% grade would not bother my 40' coach one bit. !!
That because I'd be turning around at the bottom. Heading to another campground.
Russell
CAT-RN is offline   Reply With Quote
Old 04-10-2015, 01:35 PM   #38
captnrick3's Avatar
Originally Posted by grotto69 View Post
Campsite registration email points out The Campground is located at the top of the Mountain, there is a 25% grade incline.
I'm in the FR3 30. Is there anything I need to know? or do differently?
Crazy to even try
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 04-10-2015, 02:53 PM   #39
jevanb's Avatar
I pulled my rig up a 22% grade (brockway mountain) I did not have any problems until I came down my trans did not like it and the turbo brake really helped
Sent from my SCH-I435 using Tapatalk
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-10-2015, 04:03 PM   #40
Brockway mountain drive is 13% at the steepest point.
To answer a prior posters question a 10% grade would be a 100 feet elevation change per 1000 feet of travel. In other words 520 feet up or down per mile.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
