Old 09-13-2016, 10:16 AM   #1
28DS Pantry Shelving with LED
Finished this honey-do-list-item.
3 shelves with door switch activated LED.
parts:
Cut MDF to desired size. Cut 1/2" shelveholders. Stain.
Find 12V. I found mine under the fridge by the furnace. Direct to cabinet and solder to LED strip and install the switch, LED strip 3M self adhesive wherever you choose. Stuck mine to the inside so you don't get blinded when opening the door, although LED is soft/warm anyway with 2500K.
DW is happy.
ID:	120071   Click image for larger version
DutchRv is offline   Reply With Quote
Old 09-14-2016, 06:51 AM   #2
It looks great
Tkotis5 is offline   Reply With Quote
Old 09-14-2016, 07:47 AM   #3
I like it! Thanks for sharing the stain info. I need to create some shelves and that'll help me out.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 09-14-2016, 08:51 AM   #4
Thanks Mike!
I found that I would do the porous edge first with a few coats. When dried I would stain one side, let it fully dry, before staining the other side. I used HDX Terry Staining Pads, and got nice results.
HDX Terry Staining Pads (4-Pack)-K-99488-C - The Home Depot
PS, i am not a carpenter or painter by all means, so take all this info from an amateur please
Another item I use during these projects that helps a lot:
Old 09-14-2016, 09:17 AM   #5
Thanks for the pointers. And newbie here when it comes to staining, so anything will help the beginners curve.
Another Floridian here. Grew up in Daytona Beach area for the most part and used to come down to FL for the Air and Sea show in the 2000's. Good times but crazy busy. I'm assuming with the fancy beer your drinking, you must live on one of those yachts off Las Olas Blvd!
Mike
2015 FR3 30DS
Old 09-14-2016, 12:52 PM   #6
Ahhh Las Olas, yeah not really my cup of tea, but have to be there for work quite often, and this was this morning:
Old 09-14-2016, 01:08 PM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
Looks good just be aware that the 3m taping on the LED does not seem to hold up well. I've had issues with it the past. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 62
Old 09-14-2016, 01:12 PM   #8
Thanks for the heads up. Got the stapler ready (along with thick electrical tape to not damage the strip's circuit)
Old 09-14-2016, 08:57 PM   #9
Curiouser and Curiouser
Those shelves look great!
Finch
2016 FR3 30DS
Finch is offline   Reply With Quote
led
