Old 08-19-2015, 11:03 AM   #1
30DS Air Conditioner
We are looking at getting the 30DS and live in Texas and wonder if the 15,000 single unit will handle the Texas summers?
LDStaas is offline   Reply With Quote
Old 08-19-2015, 11:21 AM   #2
Jestercyco's Avatar
I live here. I had a 15000 in my Toy hauler, and it struggled to keep up if I was in the sun. It did a good job but not when it was 105 degrees. In the trees it was a lot better.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 08-19-2015, 11:24 AM   #3
As long as Texas temps are below 90F or so. Some has installed a second AC in the rear roof vent and routed an extra 20 amp cord that could be plugged in while at the campgrounds. Usually if it hits 100F here, the 15k AC can keep it around 82 F inside without much door opening. Its a struggle though. It'll be something that we'll probably do by next year.
KansasFR3 is offline   Reply With Quote
Old 08-19-2015, 02:31 PM   #4
I know this doesn't help you guys but the FR3 on display at Goshen had a 16K Attwood AC in it. Im not sure when they did it but the factory rep told us they had switched to this AC w/heat pump in all 30ds models.
bop11 is offline   Reply With Quote
Old 08-19-2015, 03:53 PM   #5
Former Full Timer
Duckogram's Avatar
The specs say the Atwood units are 13.5k and 15k btu units with cooling equivalents of 16k and 18k. ie high efficiency heat pumps. If they work as touted, that would be a good thing.
For anyone interested in a 2nd unit at low cost, I have one available: http://www.forestriverforums.com/for...tml#post953888
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
air conditioner
