Old 04-05-2015, 01:04 PM   #11
AngioTech55's Avatar
Is the temperature for the hot water tank adjustable?
AngioTech55 2015 FR3 25DS
AngioTech55 is offline   Reply With Quote
Old 04-05-2015, 01:11 PM   #12
Ford Idaho's Avatar
In most if not all cases, no.
Old 04-05-2015, 01:13 PM   #13
Thanks Ford
Old 04-05-2015, 01:37 PM   #14
The Pic you show is for the RV pump suction side! One is for H2o the other way is for Anti-freeze! Youroo!! Keep looking for the B/pass valves!
Old 04-05-2015, 07:39 PM   #15
Technorick's Avatar
Not sure these will help. Before I winterized my coach this fall I took "before" picks of the valve positions prior to bypassing the water heater and removing the anode and turning the valve to suck the pink antifreeze up in the white tube. Assuming it's a 30ds this is what the in season valve positions should look like. This is the view after you have removed the "nuisance" panel used to help insulate the system.
Name:	ImageUploadedByForest River Forums1428280618.486052.jpg
Name:	ImageUploadedByForest River Forums1428280636.081527.jpg
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 04-06-2015, 06:38 AM   #16
Attachment 73168
Attachment 73169
2014 FR330 DS
Yes these are GOOD Pics. for the OP to figure out his H/Water problem! Very wise to take Pics. It is VERY difficult to explain Plumbing Routing in any RV! Thanks! Youroo!!
Old 04-06-2015, 06:52 AM   #17
Herk7769's Avatar
One other thing to check are your shower hand wands.
If someone has forgotten to shut off the faucet valves in the shower (OUTSIDE TOO) and just closed the button on the wand when they finished their shower, cold water will mix with the hot water inside the valve body reducing the temperature of the water at the point of use.
HAM CALLSIGN - KC3FFW
Old 04-24-2015, 01:17 PM   #18
2015 FR3
JEGNCJG's Avatar
On our first time out in our 2015 FR3 30DS. Turned on the hot water heater but it seems to be powered only with propane. Am I missing something? I expected to be able to switch between propane and electricity like my previous camper.
JEGNCJG is offline   Reply With Quote
Old 04-24-2015, 01:23 PM   #19
wmtire's Avatar
If you have the Suburban water heater, your electric switch may be on the face of the water heater. This may help:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-24-2015, 04:08 PM   #20
2015 FR3
JEGNCJG's Avatar
Thanks so much for this info! We have now located the electric switch inside the water heater! My propane will be spared! :-)
heater, hot water, water, water heater
