Old 04-24-2015, 05:03 PM   #21
HAPPY WHEN RV'ING
drivmsafe's Avatar
FR was supposed to upgrade the water heater from a propane only to propane/electric. If you have the latter, you can just leave it on electric and it will know what source you're using.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 04-24-2015, 09:59 PM   #22
Not sure how to do that will get with the dealer
mudman5206 is offline   Reply With Quote
Old 04-24-2015, 10:05 PM   #23
The frig will switch automatically if on auto, but never heard of a water heater switching from one to the other.
Old 04-24-2015, 10:51 PM   #24
Desert Kicker's Avatar
Mine automatically switches to propane when electric isn't available.
Desert Kicker
2015 FR3 30DS
Desert Kicker is offline   Reply With Quote
Old 04-25-2015, 05:33 AM   #25
Following
colourful64 is offline   Reply With Quote
Old 04-25-2015, 05:43 AM   #26
wmtire's Avatar
This is curious, as I also have never heard of it. If it's an "automatic" occurrence, as suggested, then it would seem to be one or the other. How do you use both electric and propane at the same time, if you wanted?
Have ya read posts 18, 19, and 20 on the previous page? I may be totally wrong, but have a nagging feeling ya may have been using propane only this whole time....and may have never turned on the electric heating element as per the link in post 19.... or possibly have left the electric on the entire time and then turn the propane on, if you just have the one switch inside the coach.
Here is the FAQ link again from post 19 that explains the Suburban water heater, and the TWO different switches you use to control the propane and electric heating element.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-26-2015, 05:01 PM   #27
HAPPY WHEN RV'ING
drivmsafe's Avatar
wmtire... The switch I referred to is not inside the coach. It's on the water heater. What I'm saying is that if you leave that switch in the gas position, it'll use propane only, all the time. If you set the switch to the electric side, the water heater will sense if shore power is hooked up and won't use propane.
Unfortunately, when my FR3 was built, FR was installing the propane only model water heater. They switched to the dual model about 6 months later.
Old 04-26-2015, 05:07 PM   #28
wmtire's Avatar
Curt, are you referring to the black switch on the face of the Suburban water heater, that is in the link I posted?
Old 04-26-2015, 05:19 PM   #29
HAPPY WHEN RV'ING
drivmsafe's Avatar
The switch on the model I had previously was not like the one you posted (on/off). It was labeled gas on the left, electric on the right and you set the switch where you wanted. I've not seen the one used on the FR3. But, from what I'm told, the process is the same.
Old 04-26-2015, 05:23 PM   #30
wmtire's Avatar
Are you talking about something like this:
heater, hot water, water, water heater
