04-26-2015, 07:24 PM
#41
Originally Posted by TURBS
...Oc Check your mail.TURBS
Checked and replied.
04-26-2015, 07:38 PM
#42
I would like to know what model water heater is "autosensing" the heat source used.
As far as I know, there is no model that does this.
The source of water heat (gas or electric) is USER selected, Gas, Electric, or BOTH. The two "sides" are independent and work alone.
If electric is selected "ON" and propane is selected "ON" both systems will be used concurrently to heat the water. EACH system has its OWN thermostat. They are "set" to the exact same temperature.
If you add cold water to a temperature stabilized tank, BOTH the electric and the propane turn on. This is a great way to use the water heater for faster recovery during showers when shore power is available.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-26-2015, 07:50 PM
#43
Originally Posted by drivmsafe
Yes it was a FR product. A 2011 Salem travel trailer. It was a Surburban WH. What model, I don't know.
If you're telling me you've not seen a WH that is propane/electric, I don't know what to tell you. Most have this type.
Yes, I have seen many Suburban combination propane/electric heating element models, as they have been on my travel trailers I have owned dating back to 2003. The operation of such is in the link I provided earlier on.
http://www.forestriverforums.com/for...ore-36197.html
I (as well as many others following this) just haven't seen (nor heard of) the model Suburban you are describing. This is what has our curiosity up, trying to learn something new...as in an autosensing model or one with the slide switch you describe.
I always try to post anything new or the owner/operation manuals in our library here on the forums. I just have never seen this in any of the previous Suburban manuals so far.
2011 Flagstaff 831 RLBSS
04-26-2015, 10:06 PM
#44
You folks are correct; I was wrong. I have a Suburban SW6 DE water heater in my 2015 FR3 30DS. I found the outside switch, it was in the "ON" position, so when I connected to shore power it ran on both gas and electric. When I disconnected from power and with the generator off it ran on propane only. It wasn't auto-sensing, it just appeared that way to me.
I certainly want to thank all the folks that provided input to this post. I don't believe I would have checked it out otherwise. I didn't even realize that outside switch was there.
I boondock a lot, so it isn't unusual to run pretty low on water. I turned that outside switch to the "OFF" position so that i don't accidentally destroy the element.
Desert Kicker
2015 FR3 30DS
04-27-2015, 12:18 AM
#45
This is what I was afraid was happening. I am so glad you got it figured out before the electric element was destroyed.
The Suburban water heater (with the outside electric element switch) is one of the more confusing items, and often overlooked in PDI's.
I also want to thank you for posting the model number of the Suburban water heater you have. That let's us know what is currently in the FR3 DS, for future reference and recommendations to the operation of.
04-27-2015, 04:09 AM
#46
Originally Posted by OldCoot
Not the water heater that we've not heard of but the way you describe the automatic control switching from propane to 110v.
Unless drivmsafe has some new type of WH, I'm assuming he made the same mistake.
The only auto changeover in RVs I know about, is on the fridge and the propane tanks.
04-27-2015, 09:17 AM
#47
Totally spitballing here, but I am wondering if perhaps an aftermarket electric heating element was added to a propane only water heater...... like a hott rod or lightning rod.
Let me do some research and see if the controls for any of these add-ons may have the slider switch drivmsafe is describing.
05-06-2015, 11:36 AM
#48
2015 FR3 25DS
I love discovering things about my coach. So this weekend using full hookup, I had the best hot shower using the city water inlet. So why isn't the water the same temp when using the water from the holding tanks. I must be missing something.
AngioTech55 2015 FR3 25DS
[/SIGPIC]
2015 FR3 25DS
2007 Jeep Rubicon (carried)
You just have to get your hands dirty sometime...
05-06-2015, 11:41 AM
#49
Hmmm. Shouldn't have any effect.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
05-11-2015, 07:40 PM
#50
I guess I will just have to contact the factory. I must have a defective thermostat. My hot water will not stay hot and that's the only thing I can think of.
05-11-2015, 09:03 PM
#51
Certified Curmudgeon
I have an aftermarket electric heating element (425w) added to the low end atwood propane only that came with the coach. It works just like the factory gas/electric models.
Mike Dropped
