Old 03-26-2015, 09:21 AM   #1
30DS Hot Water Heater
My hot water heats up then after using it doesn't keep the hot water hot. I might have a bad thermostat . Anyone have this problem ?
mudman5206 is offline   Reply With Quote
Old 03-26-2015, 09:59 AM   #2
TURBS's Avatar
By pass valves turned incorrectly?
Does it seem like it's hot again if you don't use it for awhile?
Does it go from hot to Luke warm to cold pretty fast?
Old 03-26-2015, 03:14 PM   #3
The hot water will be warm when I return to the coach . If I run the water for a while the water will stay warm until the heater comes on again. It seems the thermostat don't kick on as the water cools down
Old 04-04-2015, 09:40 AM   #4
AngioTech55's Avatar
I'm having a similar concern. Water doesn't stay hot for the length of a quick camping shower.
AngioTech55 2015 FR3 25DS
AngioTech55 is offline   Reply With Quote
Old 04-04-2015, 10:09 AM   #5
TURBS's Avatar
Are your bypass valves turned correctly?
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 04-04-2015, 01:46 PM   #6
Good question. Where are the bypass valves located.
Old 04-04-2015, 02:05 PM   #7
leisurelarry's Avatar
I timed my hot water run out time in the shower. I get 5-6 minutes of hot water using a mix and then completely closing the cold water valve for the last 2 minutes. Much longer if I shut the shower head off between rinsing.
leisurelarry is offline   Reply With Quote
Old 04-04-2015, 02:43 PM   #8
TURBS's Avatar
Most likely.
Behind the hot water tank.
TURBS
Old 04-05-2015, 09:41 AM   #9
On an FR3 there is no acess behind the water heater. Should lbe below near the fresh water tank. At least on my 25DS.
zippyzrx is offline   Reply With Quote
Old 04-05-2015, 11:41 AM   #10
[ATTACH]73147[/ATTACH
Ok so I found the bypass and this is the factory position, meaning I have not turned anything. Is this the fresh water fill? If I connect to the city water do I turn the valve left or right?
Name:	ImageUploadedByForest River Forums1428251994.824830.jpg
heater, hot water, water, water heater
