Old 05-01-2016, 01:12 PM   #1
A/C Problem
Having water leaking from the unit inside. I removed the inside cover an the water is running down the inside where the fan blade seems to be hitting it an spaying water out of the vent cover. Removed the cover on the roof an could not see any issues, other than some water buildup in a couple areas but I think what I saw was normal. Had two water trails on each side of the unit up on the roof but thats just normal run off I believe. Anybody have any ideas what I can check without having to drive back to the dealers? The water is coming into the unit fairly heavy while the unit is running day or nite.
jogalot is offline   Reply With Quote
Old 05-01-2016, 01:35 PM   #2
raspivey's Avatar
That's typically plugged up drains on the roof. IIRC, they're just rails with drain holes on the outsides.
Old 05-02-2016, 07:03 PM   #3
Thanks for the reply. Talked to a rv a/c man today an he said to check the 4 mounting bolts from the inside to see if they are tight, if so then the problem is the gasket is causing the leak problem. This thurs. nite I shall see.
Old 05-02-2016, 07:29 PM   #4
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
I've had my main Dometic a/c unit replaced three times in two years. This last replacement we had a water leak. The four adjusting bolts weren't tight enough against the heavy gasket. We tightened them and leak went away.
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Heart issues-laid up for a spell
dwhit is offline   Reply With Quote
Old 05-02-2016, 08:24 PM   #5
I have a gasket still in the box if you need it. I don't plan to use it anytime soon, so you can have it.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 05-02-2016, 08:31 PM   #6
Thanks guys, hopeing its just the bolts, will let you know thurs. eve. If I do need the gasket I will ask.
Old 05-09-2016, 03:05 PM   #7
Got busy an forgot to reply back. Ran the unit for 1:55 min an no water issues, can't understand. Tightened the 4 mounting bolts a little but I don't think that was my issue, the water is running down the fan blade shoot, has to be condensate problem I believe. Its one of these crazy issues we rv owners get from time to time.
Old 05-09-2016, 04:06 PM   #8
Thanks for coming back with your reply.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-13-2016, 08:08 AM   #9
Every now and then we'll get some water dripping out of our Dometic 15k unit. And typically its when its fairly warm and humid. We just crack open the cold blast vent for a little until the unit is cooled down a bit, then run it through the ducts. Anyways, hope it goes away for good.
KansasFR3 is offline   Reply With Quote
Old 05-13-2016, 08:31 AM   #10
Flybob's Avatar
If it is a Dometic unit, Here are the specs for tightening the bolts. 40-50 in/lbs
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
