Old 01-30-2016, 01:32 PM   #1
Edmo's Avatar
AC Unit 2016 FR3
I see all the posts on the relatively poor AC units on the fr3.
Picking up a 2016, was anything corrected, does the fr3 really need a 2nd AC unit and is the vehicle AC that poor.
My current 2010 class C AC works great.
Hmmmm maybe a deal breaker.
Please post comments
Edmo is offline   Reply With Quote
Old 02-18-2016, 01:22 PM   #2
I had to have my AC replaced on my 2016 FR3 as it was not cooling. My dealer took care of it without any problems though both of us had to take the makers to task.
I've not used it yet due to the weather but previous 5 Class A motorhomes needed only 1 AC to keep it very comfortable. Expecting the same with this one.
Richard Tribble is offline   Reply With Quote
Old 02-18-2016, 01:39 PM   #3
StephanFR3's Avatar
They have put progressively bigger A/C's on the FR3 the 2014 came with one Dometic 13500 btu, The next year with Dometic 15000 btu. Now the have a Atwell 18000 btu equivalent. Some people get a separate wired A/C for the rear vent. The 32 foot comes with 2 A/C's but it is also 50 amp. with a bigger genny. look through the old posts. Its been addressed before. You can also tint windows and use reflective auto shades. it helps a lot and is a lot cheaper.
StephanFR3 is offline   Reply With Quote
Old 02-19-2016, 09:39 AM   #4
JMO, but it NEEDS 2 ACs. But it depends how cold you like it I guess. Our expectations is to keep it between 70-75F inside. But if its above 90F outside, it'll hover around 80F+ inside. We've tried the vent pillows and bubble insulation and that helps, but for $700 or so for an extra AC unit, we'll be installing one this spring. We'll just run an extension cord down to the power bay and everything will be good. You might see if you can't get the dealer to install a second one before you pick it up for a little extra money on top of your sales price.
KansasFR3 is offline   Reply With Quote
Old 02-19-2016, 12:12 PM   #5
StephanFR3's Avatar
Just remember that the 4000w generator can't handle the start up of both A/C ' s at the same time.
Old 02-19-2016, 01:04 PM   #6
Yeah, we know that. We may get a separate generator to run only that AC if we need to. But having two AC when we have hookups is about 80% of our needs. Even thought about swapping in a 5500 gen, but don't think its worth it. Best just to buy the Yamaha 2400 gen or the like and mount it somewhere on the LH side by gen/hydraulic jack pump...For now, we just want one installed so we can hook it up to a pedestal.
Old 02-19-2016, 02:04 PM   #7
StephanFR3's Avatar
Cool
Old 02-19-2016, 10:09 PM   #8
Edmo's Avatar
I really hope that the 18,000 btu is enough, my current class c 14,000 btu unit is ice cold in the hot weather. Don't want to buy this fr3 and have to throw thousands of dollars into it
Old 02-19-2016, 11:52 PM   #9
b1barnes's Avatar
Fr3 is very poorly insulated, thus AC does not work well in hot weather. The insulation factor is the key why some other units and TTs cool with smaller units.
Last summer in STL at 95 the FR could almost get to 85.
We installed two Atwoods and changed the Gen to 5500. Tinted the windows.
b1barnes is offline   Reply With Quote
Old 02-20-2016, 09:29 AM   #10
I had FR swap out my Dometic for the Atwood and seal the front and rear ceiling caps. It's slightly better, but don't expect comfort in direct sun and 90+ temps outside. It just can't keep up.
I had a 30' Cougar TT prior to this and the 15K AC kept that thing like an ice box inside, even in 100 degree weather. I do think the insulation sucks on the FR3, but not sure how to improve it.
2015 FR3 30DS
MaltnHops is offline   Reply With Quote
