Old 08-27-2016, 10:46 AM   #1
AC water intrusion when heavy rain
Pretty heavy dripping from ac when rain is heavy and sideways (coming into roof ac from the side I pictured it)
Wiring inside ac above filter all wet as well.
There is a puddle of water underneath the black bracket where the whole ac assembly is attached through roof.
Any ideas to remedy folks?
ID:	118532   Click image for larger version
ID:	118534   Click image for larger version
DutchRv is offline   Reply With Quote
Old 08-27-2016, 11:34 AM   #2
Tighten your bolts down a little bit
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 08-27-2016, 11:52 AM   #3
Thanks!
These ones from the inside?
Old 08-27-2016, 12:56 PM   #4
Yes should be 4 of them but don't over tighten them
2016 Flagstaff 23lb
Old 08-29-2016, 08:36 AM   #5
Wolverine 1945's Avatar
Wouldn't that just be normal in a rain storm ???
Wolverine 1945 is online now   Reply With Quote
Old 08-29-2016, 08:40 AM   #6
No. The condenser and evaporator are completely isolated from each other. Rain or water blowing in The condenser will not come inside.
Old 08-29-2016, 08:52 AM   #7
Agreed.
And thank you Todd, I tightened all four of them (2 of them where quite loose) and no more intrusion. Thanks for the tip and easy fix!
water
