Old 10-08-2015, 07:36 PM   #1
Tents2RV
Add water to fresh water tank
We are boon docking in our 2015 FR3 30DS and are running low on fresh water. How can I get water into the tank using the winterization tube in the bypass compartment area? Thanks for any help.
c0nnd0r is offline   Reply With Quote
Old 10-09-2015, 04:21 PM   #2
I don't think you can fill the tank through the winterization system. The winterization system is meant to bypass the tank and fill the pump and lines only with antifreeze. To top off the tank, I use a bucket and funnel.
prestonj12 is offline   Reply With Quote
Old 10-09-2015, 04:30 PM   #3
Ford Idaho's Avatar
Something like this?
Old 10-09-2015, 05:01 PM   #4
fonzie's Avatar
You could use the anti-freeze inlet to pressurize system with water pump and then use outside shower with adapter hose to your fresh water tank fill connection.......
Fonzie
Old 10-09-2015, 07:56 PM   #5
TLAK's Avatar
The antifreeze hose on an FR3 works fine. It is a short hose with a plug on the end, located in the water pump compartment. Take the plastic cover off the compartment while you work so you can get at everything. Unscrew the plug, stick the hose in your water container and turn the pump on, it will suck the water into the tank. Remember to put the plug back in when you're done. I use it when I decontaminate the water system so I know it works.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 10-10-2015, 12:44 PM   #6
True, when you switch the valve it goes from sucking out of your main fw tank to what ever the hose is stuck in. I use a 5 gallon jug.
This pressurizes your water lines from your pump. The only way to get it into your fw tank would be to do as you suggest. I don't need any adapter. I can just remove the shower head and stick the hose into the fw fill port, open the cold water and turn on my pump.
Most of the time I don't bother, I just use the water from my jug and fill it back up when it gets low.
Jim
ID:	91123   Click image for larger version
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-11-2015, 11:30 AM   #7
Tents2RV
Thanks for all of your suggestions. Even though not all of them worked for me, they helped me better understand how my system works. I was able to use the antifreeze hose and Walmart gallon jugs of water. I could not get the water into the fw tank, however the pump will draw from the jugs whenever we need water for sinks or toilet. I will buy an adapter for the outside shower and also look into buying a water 'bladder' for carrying extra water. Again thanks to all for sharing your expertise.
Old 10-11-2015, 12:49 PM   #8
BillyBass's Avatar
i use a plastic 55 gal drum and a pump and 25 ft hose
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 10-13-2015, 08:55 AM   #9
Get an adapter to attach a hose to a faucet. Attach your water hose and hook the other end of the hose to the fresh water inlet port. With the system set to winterize, the pump will draw water from a jug, pump it out through the faucet then through the hose into the fresh water tank. This works best with a 5 gal camping water jug which can be squashed flat when not in use.
Phil
pmsherman is offline   Reply With Quote
fresh water, tank, water, water tank
