Old 03-10-2015, 07:58 PM   #21
JerseyGuy's Avatar
Just finished wiring mine. I used the existing a/c duct (actually a gap in the ceiling running from the front unit all the way to the rear wall. I removed the panel that runs along the rear wall and ran the wire into the rear closet. I then ran the wire down the closet into the electrical bay. Click image for larger version
Name:	ImageUploadedByForest River Forums1426035496.325663.jpg
ID:	71131Click image for larger version
Name:	ImageUploadedByForest River Forums1426035509.841629.jpg
2014 FR3 30DS In New Jersey
JerseyGuy is offline   Reply With Quote
Old 03-11-2015, 05:14 AM   #22
JerseyGuy's Avatar
Do you have the model number for the breaker box? I'm using a fused A/C box but I like yours better.
Old 03-11-2015, 07:55 AM   #23
PDG
PDG's Avatar
2nd AC unit breaker box
JerseyGuy,
I liked the way you did your wiring, nice job!
The breaker box is a basic Square D 2 circuit slots. Home depot Square D Model # HOM24L70SCP Internet # 100202333 Store SKU # 565539
$14.34
The 20 AMP breaker is separate and located right next to the breaker box area.
Also, check this dog bone RV 50A Male to (2) 30A Female Lighted "Y" Adapter by ECS electric cordsets. I called them, very knowledgeable and helpful.
URL is:
This adapter allows you to be at an older RV park that only has a 50 AMP outlet on the pedestal and no other outlets available. (Had several like that on my trip out west last year).
It splits the 50 AMP service so we can individually power the coach and the 2nd AC from one 50 AMP outlet. Very cool.
Let us know how this project continues.
GLTA
Peter & Linda
2014 FR3 30DS - Fiat 500
PDG is offline   Reply With Quote
Old 03-12-2015, 03:48 PM   #24
JerseyGuy's Avatar
I will order the adapter. I've finished the wiring but the actual unit will not be installed until May when we get to Phoenix.
I've arranged to have the unit dropped in at a dealer in AZ.
Name:	ImageUploadedByForest River Forums1426193251.828925.jpg
ID:	71215Click image for larger version
Name:	ImageUploadedByForest River Forums1426193268.943644.jpg
Old 05-15-2018, 03:07 PM   #25
I also have a 2014 FR3 30DS and am planning on doing the same thing. Did the installation go as planned? If you don't mind could you tell me how you ran the wiring and briefly summarize what you did?
thanks much!
LCraddock is offline   Reply With Quote
Old 05-17-2018, 02:08 PM   #26
thanks much!
I added a 2nd A/C to our 2015 28DS. Snaked the wire though the 'duct' (really just a channel cutout in the styrofoam) and down to the electric bay through a closet. The second A/C is wired on it's own separate 15AMP outlet. So when at home or camping, I run the bus (with original A/C) on 30AMP, and the second A/C completely separate on 15AMP. Note that while driving/boondocking I CANNOT run that second A/C...
While snaking the proper wire through the duct, please make sure you don't expose wire by 'scraping' the screws from the vents, they're very sharp...
DutchRv is offline   Reply With Quote
Old 05-17-2018, 08:32 PM   #27
What gage wire you using to get down to the 20 amp breaker? From there you run a std plug to the 20 amp pedestal from the breaker box?
Combatcoal is offline   Reply With Quote
Old 05-18-2018, 07:48 AM   #28
I used yellow romex 12/3. And since I wanted this A/C to be on a separate 20amp service, I didn't use the RV breaker box panel. Just it's own receptacle so I can power the 2nd AC. I did add a 15amp inline fuse that will before before the (20amp) breaker at the pedestal trips, for added protection.
Old 05-18-2018, 08:35 AM   #29
Awesome stuff Dutch, thx, I believe you also shared pics too, thx for that also
air conditioner
