Old 02-09-2016, 12:43 PM   #21
from Cali
RV Pilot's Avatar
None yet. I started with the batteries to first determine how much power I will be using per day (approximately). That way I will know how much solar to add. I'm thinking between 200 and 400 watts.
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
Central Coast of California
RV Pilot is offline   Reply With Quote
Old 02-09-2016, 02:08 PM   #22
from Cali
RV Pilot's Avatar
All done for this trip. I'll do some cleaning up and painting when I get home. It's now probably one of the strongest things on the RV.
Name:	ImageUploadedByForest River Forums1455048425.011778.jpg
ID:	99255Click image for larger version
Name:	ImageUploadedByForest River Forums1455048444.699688.jpg
ID:	99256Click image for larger version
Name:	ImageUploadedByForest River Forums1455048461.649916.jpg
ID:	99257Click image for larger version
Name:	ImageUploadedByForest River Forums1455048478.066299.jpg
2015 FR3 30DS
2015 FR3 30DS
2014 Jeep Rubicon X
Old 02-10-2016, 12:49 AM   #23
Tom48's Avatar
They say about 100 watts per 100 amps of battery so I guess 200 plus for two golf cart 6's and with the second set, at least 400. We run three group 24s and so about 240 amps of battery with 200 watts of solar and our camping partners have 400 on the roof with 4 6's. We both have the Onan 4.0 gens but hardly use them unless we need the AC, lengthy use of the microwave (it warms stuff fine just on the inverter) or use of the convection oven.
Are you running a residential frig in the 30DS? Absent that, you should have a ton of power with the 4 batteries for now, but the solar brings it all together. Gone with the WINNS on YouTube have a great video on how their 6 panels were installed. They used the rather pricey GoPower 160 watt panels but seeing it get installed is interesting. We used a WindyNation.com 200 panel set for just over $300 and it has been great and with their slightly upgraded charge controller there is capacity for 200 watts more.
Tom48 is offline   Reply With Quote
Old 02-10-2016, 12:50 AM   #24
Tom48's Avatar
Oh those are 12 v batteries! Are they 24s or 27s?
Old 02-10-2016, 08:53 AM   #25
All done for this trip. I'll do some cleaning up and painting when I get home. It's now probably one of the strongest things on the RV...
Without a doubt!! When you get ready to consider a solar addition, drop me a private message. I have done a lot of research and also spent time in the solar power monitoring business. Everything that I have discovered and designed for a solar upgrade for my 335DS should be equally applicable to your FR-3, as they are laid out and wired virtually identically.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 03-05-2016, 08:47 AM   #26
PeteAndEd's Avatar
Before we upgraded the original two 12v house batteries to 2 6v deep cycle batteries, I had a 2nd battery tray installed. It was a tray for a Jeep, but it holds 2 6v deep cycle batteries with no room to spare. Robot Check I like this tray as it has a higher bracket on the back. I drilled holes for the 3 bolts into the I-Frame and had a welder weld around the back part for extra protection. After putting the 6v batteries on it, I felt it was still wobbly, so I added a support piece on the left front of the tray to give it additional stability. The 3rd pic shows the welder guy inside that compartment!
ID:	101105   Click image for larger version
ID:	101106   Click image for larger version
FR3 2015 30DS
PeteAndEd is offline   Reply With Quote
Old 03-11-2016, 08:00 PM   #27
from Cali
RV Pilot's Avatar
I sent you a pm.
For everyone else this is what I'm considering. Any input welcome.
http://www.amazon.com/dp/B00E0YBL0K?psc=1
2015 FR3 30DS
2014 Jeep Rubicon X
battery
