Old 02-04-2016, 10:20 AM   #1
from Cali
RV Pilot's Avatar
Adding batteries to the FR3
The first change I did to the coach was to change my two 12 Volt house battery's to two large 6 V golf cart batteries. If it's quite cold during the night and the heating system runs frequently the two batteries seem very low by morning. I want to add two more in the compartment. Has anyone else done this and what type of mounting tray solutions did you come up with?
2015 FR3 30DS
Central Coast of California
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
RV Pilot is offline   Reply With Quote
Old 02-05-2016, 01:06 AM   #2
lornav's Avatar
I sure hope someone can answer your question as we recently picked up a 2015 FR3 30DS (So far its been great) and would like to do the same. Were you able to use the existing battery tray for the golf cart batteries? And what G.C. batteries did you use? Thanks in advance!
lornav is offline   Reply With Quote
Old 02-05-2016, 07:14 PM   #3
from Cali
RV Pilot's Avatar
Hi lornav, congratulations on the new coach. I installed to Trojan T105 6V. ( T-105 | Trojan Battery Company ) they fit on the try just fine. They were slightly taller, so I had to turn the plastic cover over and drill a new hole for the wing nut. I really have no idea how much I gained from this change. I do know I would like to have at least twice the battery Power I have now. BTW, I also installed 2000 watt 110v Inverter.
2015 FR3 30DS
2014 Jeep Rubicon X
Old 02-05-2016, 08:41 PM   #4
lornav's Avatar
Thanks RV Pilot for the good info! I'm a big Costco fanboy and I've seen that they carry Interstate GC2 batteries for about $84.00 so with your info I'll be able to figure my best options. Still going through a steep learning curve but of course that's half the fun I hope someone can shed some light about adding a couple more in the same area along the frame. In the mean time I'll be beating the bushes of the great internet knowledge base and I'll let you know if I find anything good.
Old 02-05-2016, 11:50 PM   #5
Retired guy
Big Dog 1's Avatar
Just upgraded our two 12 volt batteries to two six volt heavy duty. They provide faster recovery time in recharging. They also work better with our 300 watt solar panels.
2015 30DS
Monterey CA
Big Dog 1 is offline   Reply With Quote
Old 02-06-2016, 05:42 PM   #6
2015 30DS
Monterey CA
Do you find the two 6 volt batteries and the 300 watt solar work good together? I have been trying to figure out the right setup. Thanks
XLR 24 HFS
Bpenn is offline   Reply With Quote
Old 02-06-2016, 06:41 PM   #7
Anders's Avatar
We use two 6 volt flooded Interstate Deep Cycle Extreme (232 Ah) in our fifth-wheel with the Solar Elite system. We are currently in Mexico with our rig and in November - December we were camping on the beach for 6 weeks with no shore power, only solar, and it all worked fine, including Nespresso machine, wife's hair dryer etc. Driving down the Baja Peninsula over 2 days, in full sunshine, the solar system ran the fridge just fine.
However, another bank of batteries will be installed when we get home for extra storage and we will use more power next trip with the addition of a satellite dish. I will have to do some modification to make sure the batteries are vented properly.
Anders Cortes Island, BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab
Harness: Hijacker 24-AS-18 Autoslide, Demco Glide Ride Pin Box
Chuckwagon: 2011 Rockwood 8265WS
Travel Blog
Anders is offline   Reply With Quote
Old 02-06-2016, 07:52 PM   #8
Technorick's Avatar
I've stared at the battery compartment many times wondering how to (eventually upgrade) and get 4 six volt golf cart batteries in there. Although there is plenty of open space in there, With the battery control center hanging on a steel plate off the frame there seems to be little space to weld or bolt a larger battery tray without removing the factory install and a totally custom Hanger retrofit.
I've seen here that a member has place two six voters in but If anyone has already (fit 4-6volt GC batteries) I'd love to see pics of the install.
Name:	ImageUploadedByForest River Forums1454809436.785721.jpg
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 02-06-2016, 08:10 PM   #9
While I can't tell how your battery bay is configured, I sent these pictures to another forum member who wanted to expand their capacity to 4 deep cycle 6 volt units. This is from my 335DS with a residential refrigerator. (Sorry about the rotation)
ID:	99066   Click image for larger version
ID:	99067   Click image for larger version
ID:	99068   Click image for larger version
ID:	99069   Click image for larger version
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-06-2016, 08:56 PM   #10
Technorick's Avatar
Good example. Thanks. That deeper narrow battery tray would definitely work in my space. The support arm in the first pic must go up to the floor would be necessary in my case as the outer side wall (skirt) where the door is would not support the weight.
If I could find a factory made tray of those dimensions I think I could install myself. As for now my current batteries are fine.
2014 FR330 DS
battery
