Old 10-07-2016, 02:35 PM   #1
Vudu13's Avatar
Air Conditioner Went Kaput 2015 FR3 30DS
We were in Tucson in March of this year, and the air conditioner started acting strange. And then the breaker would trip every so often. I saw other posts about moving the breaker to a different slot, so that it would not overheat next to the 30 amp breaker. The problem still continued, tripping the breaker every hour or so. We returned home and brought it in for service. Come to find out, the air conditioner was faulty, drawing too much amperage.
The service tech said the air conditioners on the 2015 FR3's were recalled. I cannot find anything on a recall. We replaced the unit ($1200). Does anyone, or has anyone experienced this issue? Will FR reimburse for at least part of the cost?
Any thoughts out there?
Vudu13 is offline   Reply With Quote
Old 10-08-2016, 03:06 AM   #2
Following
colourful64 is offline   Reply With Quote
Old 10-10-2016, 08:21 AM   #3
See if you can get some more info on the "recall" that the tech mentions. Its the first I've heard. $1200 seems steep IMO for a drop in replacement for an AC unit that goes for around $7-800 new. I hope FR would help you out with the expense if there is such a recall out there. If you can get a copy, please share. Thanks.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 10-10-2016, 08:31 AM   #4
AquaMan's Avatar
I don't think it was so much of an FR recall, but more of a Dometic (I'm assuming this is what you have) recall. There were a batch of 2015 15k ACs that were on multiple different units and brands. And, it was probably more of a TSB than a recall.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 10-10-2016, 10:12 AM   #5
PeteAndEd's Avatar
What specific model do you have?
Also, have you checked the warranty on the AC unit? If I have the same model, I could probably get a copy to you. However, the work has been done already, so... it may be too late.
FR3 2015 30DS
PeteAndEd is offline   Reply With Quote
Old 10-10-2016, 10:30 AM   #6
Witch Doctor's Avatar
Dometic A/C comes with a two year warranty. The second year you should have taken it to their authorized service centers. FR is out of it after the first year unless you bought the FR 2nd year. I would call Dometic on this..Good luck...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-10-2016, 05:52 PM   #7
twojump36's Avatar
I had mine replaced this year on warrantee.... only used it once before it went out and once since it's been replaced....
2015 FR3 30 DS
1995 Wrangler
Miles 3708
Days Camped 30
twojump36 is offline   Reply With Quote
Old 10-10-2016, 09:06 PM   #8
also following.....
Celkalee is offline   Reply With Quote
Old 10-11-2016, 08:13 AM   #9
Retired Retail/Importer
On our new 2017 360PDEK our ac went out the first week...no help from dealers so I got up there and discovered that the telephone style wiring from the thermostat was sitting in water...I cut and replaced the connectors with a tool and parts from ace hardware. I called FR and they said the return vents were to shallow do they sent me two more matching vents covers. I cut two more return vents inline with the originals...now the condensation has been taken care of and water is not leaking through our running ceiling fan as before! I drilled out some of the plastic walls housing the ac. To allow better drainage too...I just was appalled at the lack of help RV dealers want to do warranty work
pledbetter is offline   Reply With Quote
Old 10-11-2016, 09:10 AM   #10
AC Failures
No mention of the voltage. When the voltage goes down, AC and other devices draw more amps/current, that's heat. AC is one item that will try to run on low voltage and end in melt down. I have a Progressive Industries surge protector, LED screen shows voltage, amps etc., shuts down power for low or high voltage on either leg. Camp ground power was L1 120V, L2 90V (AC), they corrected the situation.
DJsFolly
D. J. Schuler is offline   Reply With Quote
air conditioner
