Old 03-04-2015, 05:58 PM   #11
GerryW's Avatar
I agree completely, Both over and under inflation damage tires, affect tire life and handling. Use tires the way tire mfgr recommends, use common sense and check often. On previous unit I put 110,000 miles without tire problems following this process. I hope to do 100,000 more. Going with the max will work for many people because units are at upper limits for weight. Mine isn't.
GerryW is offline   Reply With Quote
Old 03-04-2015, 06:38 PM   #12
HAPPY WHEN RV'ING
drivmsafe's Avatar
Air for tires
Welder. Not sure what you're driving, but, There is a sticker on the bulkhead next to the driver seat that will give you recommended tire pressure. I run 84 pounds in my 30DS.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 03-04-2015, 06:40 PM   #13
StephanFR3's Avatar
What drivesafe said.
StephanFR3 is offline   Reply With Quote
Old 03-04-2015, 08:42 PM   #14
Brewster McFrisk's Avatar
I run 82 psi in my 25DS, gives a little softer ride!
Brewster McFrisk is offline   Reply With Quote
Old 03-05-2015, 06:21 PM   #15
Bobb36's Avatar
Originally Posted by Ford Idaho View Post
Whatever it says on the sidewall of the tire.
This sidewall only has a max pressure, always use vehicle tire recommendations
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 03-05-2015, 06:24 PM   #16
Ford Idaho's Avatar
Would/should the two not coincide with each other if the correct size tire is installed?
Old 03-05-2015, 10:08 PM   #17
StephanFR3's Avatar
If the maximum side wall pressure is less than the placard you have the wrong tires. But I doubt that would exist. The proper pressure is what the placard says. But never exceed the maximum side wall pressure. True you can play with the pressure like Nascar mechanics do to change handling. But non optimal tire wear will result. And if you overheat your tire it will fail.
Old 03-10-2015, 05:58 PM   #18
I purchased a remote air pressure monitor and highly recommend one for everyone. Mine monitors 8 tires. 6 on my 30DS and 2 on my toe dolly.
mudman5206 is offline   Reply With Quote
tire, tires
