Old 08-29-2019, 12:13 PM   #1
Air suspension
Has anyone installed air suspension on their FR3? Is so, what kind, what was the cost. The roads in Ontario and Quebec are the worst.
johnpisue is offline   Reply With Quote
Old 08-29-2019, 01:02 PM   #2
robo44's Avatar
I have not installed Air Suspension, (I know that as your question)
but you might also look at Sumo Springs for which I have installed. I drive on California Roads which most are horrendous. I can say in my case I would 100% endorse adding Sumo Springs to all four corners of any RV. Went from losing teeth on every drive to one that is smooth as glass. Best of luck
2019 FR3 33DS Motorhome
Travels California Coast & Beyond
robo44 is offline   Reply With Quote
Old 08-30-2019, 09:27 AM   #3
Thank you robo44, i have ordered the sumo springs.
Old 08-31-2019, 08:07 PM   #4
Arvee Pilot
Old Oregoner's Avatar
Sumo Springs are great for reducing lean and rocking side to side but won't provide what an Air Ride suspension can. I can't answer the question, but I am following
2019 FR3 30DS
Toad: 2010 Explorer Ltd
Old Oregoner is offline   Reply With Quote
Old 09-01-2019, 09:21 AM   #5
Arvee Pilot
Apgar Campground, Clearwater NF, Idaho.Click image for larger version
ID:	213946Click image for larger version
2019 FR3 30DS
Old 09-09-2019, 08:28 PM   #6
Arvee Pilot
Sorry, pics weren't for this thread!
2019 FR3 30DS
Old 09-20-2019, 10:35 PM   #7
ive added Firestone RideRite airbags to my 2014 25DS. Made a huge difference in the ride of the short wheelbase. Took all the harshness out of it. Was the single biggest improvement to the ride.
KY25DS is offline   Reply With Quote
Old 09-20-2019, 10:39 PM   #8
This seems to be the real way to go. www.liquidspring.com around $7500 installed. I think.
nvs4602 is offline   Reply With Quote
Old 09-21-2019, 07:47 AM   #9
Arvee Pilot
Air Ride
I checked the Firestone site and there isn't a kit listed for F53 motorhomes, only Class C.
Old 09-21-2019, 07:55 AM   #10
Arvee Pilot
LiquidSpring
Their site lists a kit for F53 based MY but only up to GAVR 17500
Old 09-21-2019, 02:51 PM   #11
rk06382's Avatar
Your FR3 30DS is only 12,000 lbs GAWR. (see below) I looked at Liquidspring but there is no Dealer in Alaska.
Check with a Liquidspring dealer near you. Please report back after talking to them.
From: liquidspring.com/wp-content/uploads/2016/12/Ford_F53_Full_Line_Tear_Sheet.pdf
- DS120F53: 12,000 lbs GAWR Dana 80
(16,000/18,000 lbs GVW)
- DS135F53: 13,500 lbs GAWR Dana S110
(20,500 lbs GVW)
- DS150F53: 15,000 lbs GAWR Dana S130
(22,000 lbs GVW)
- DS175F53: 17,500 lbs GAWR Dana 17060S
(24,000/26,000 lbs GVW)
From: www.forestriverinc.com/brochures/2020/2020fr3brochure.pdf
FR3: 28DS & 30DS
Wheelbase: 190"
GVWR: 18000 lb.
GCWR 23000 lb.
GAWR Front: 7000 lb.
GAWR Rear: 12000 lb.
FR3: 32DS, 33DS & 34DS
Wheelbase: 228"
GVWR: 20500 lb.
GCWR 26000 lb.
GAWR Front: 7500 lb.
GAWR Rear: 13500 lb.
Robert
2018 FR3 28DS | Samlex EVO-3012 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads | Koni Shocks | SumoSprings |
Solar Power & Battle Born batteries thread
rk06382 is online now   Reply With Quote
Old 09-21-2019, 06:35 PM   #12
Arvee Pilot
Doh! My bad! Thanks for getting me on the right track.
2019 FR3 30DS
suspension
