Old 03-13-2019, 10:30 AM   #1
AM/FM Antenna Replacement Ideas
Has anyone tried replacing and had good luck with a replacement antenna for the stock metal & spring AM/FM antenna on the roof? I don't have an issue with the reception I get through it but there's got to be something better....more low-profile, better seal to the roof, not going to rust, etc. Mine was loose when I inspected the RV for it's final trip back to the dealer for warranty service before my year's up, and now that I've taken a good look at it I'm more worried about the flex of the antenna against the sealant at the base/roof and how it seems that's a strong possibility for future water intrusion.
FarFromLiberal is offline   Reply With Quote
Old 03-13-2019, 10:46 AM   #2
I have the same antenna and haven't replaced it. Be grateful that you are getting good reception. Mine does ok on FM but the AM is nonexistent. I di try changing the antenna cable and that didn't help.
2007 Dodge Ram 1500 Hemi
2017 Flagstaff 21ds
WTP2 is offline   Reply With Quote
Old 03-13-2019, 10:56 AM   #3
bubbles's Avatar
It's a thin wire antenna and the flex of the antenna would only occur if it were to come in contact with a fixed object, like a tree limb. That flex would be a good thing to have. I position my identical antenna back at a 45 deg angle for that reason. Have not had any reception or sealant issues.
Old 03-13-2019, 06:20 PM   #4
I never re-installed my antennae after having the roof repaired. I just use streaming or CDs.
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
Old 03-13-2019, 08:44 PM   #5
I honestly haven't taken mine anywhere yet where I should be able to get decent reception on at least a few FM stations, and haven't tried the AM at all yet. But I lived in Ft. Collins for a handful of years in the 90's, happily, and have traveled by car/pickup out Rte 70 and across to Gunnison many times where I was happy to have any AM reception come in! I occasionally look at real estate out there, looks like Ft. Collins and Loveland have grown up quite a bit since I was last there 20+ years ago.
Old 03-13-2019, 08:54 PM   #6
Thanks for the advice. I'm still a bit green to RVing, and trying to think ahead of the next potential problem or be preventative as much as I can. More worried about how the thick sealant is around and over the spring base part of the antenna where it enters the roof, and if the flex of that spring over a period of time in winds & through highway-speeds traveling may pull that sealant away from the spring and allow a leak. Probably overthinking it...
Old 03-13-2019, 08:56 PM   #7
Thanks, that's probably the best advice for not having to worry about the thing leaking! And might be worth the trade-off of not listening to local channels- can probably get most of them via streaming now too anyhow.
Old 03-14-2019, 09:45 AM   #8
edm
We lost our rubber roof because of that antenna braking loose and letting the wind in under the membrane. We elected to not replace the antenna and are using a small ribbon antenna stuck to the windshield. it works well enough. we don't us the radio that much we use recorded music most of the time.
edm is offline   Reply With Quote
Old 03-14-2019, 09:57 AM   #9
Wow, I hadn't considered that possibility at all! Thank you for sharing that, definitely pushes me further toward getting rid of the antenna altogether or at least trying to replace it with something much smaller and aerodynamic.
_______________________________________
Bill
2019 FR3 32DS
Old 03-14-2019, 05:17 PM   #10
We love Boyd Lake State Park in Loveland. We stay there when we visit our daughter.
OldGunny
2016 FR3 30ds
antenna, replacement
