Old 10-09-2017, 10:07 PM   #1
gomatthew's Avatar
Anode Rod for 2015 FR3 DS30
Anyone know what the right size is to replace the anode rod in the water heater? Wanting to order it from Amazon and be there when I get back.
gomatthew is offline   Reply With Quote
Old 10-09-2017, 10:29 PM   #2
Suggest you state what make/model your water heater is, NOT what unit you're driving.
They're pretty standard. I'd remove the one you have, take it to Home Depot, and find one just like it there.
2011 Traverse LT, 3.6L, FWD
Old 10-09-2017, 10:47 PM   #3
Hogq's Avatar
My 2015 FR3 has a Suburban water heater, they are glass lined and require anode number 232767.
2015 fr3 30DS, added 2nd A/C-Heat Pump, converted to 50amp, CHF with Hellwig Links, Progressive Power Management, TPMS, Blue Ox True-Center, Koni Shocks, HID Headlamps, LED Foglamps, Pioneer Stereo, Keyless entry, Auxiliary Cooling Fans for A/C Condenser.
Hogq is offline   Reply With Quote
Old 10-11-2017, 10:52 AM   #4
I've replaced ours before with a Suburban 232767/Camco 11562. Cheapest on ebay.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 10-11-2017, 11:01 AM   #5
Flybob's Avatar
I always suggest buying two. You save a trip or postage and if you keep the RV, you will need to replace in a year or two.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-11-2017, 11:40 AM   #6
Suburban used a standard 3/4NPT anode rod about 10 inches long. Atwood does not use an anode rod.
donniedu is offline   Reply With Quote
Old 10-11-2017, 01:54 PM   #7
PeteAndEd's Avatar
Our 2015 FR3 30DS, with a Suburban gas/electric water heater, uses this one:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
FR3 2015 30DS
PeteAndEd is offline   Reply With Quote
Old 10-12-2017, 07:41 AM   #8
I switched to aluminum anode three times out flush out water heater after every btrip rod is like new if your still in unknown land call suburban they will point in the right direction.
polishapple is offline   Reply With Quote
Old 10-12-2017, 09:06 AM   #9
Hogq's Avatar
Since the anode is designed to be sacrificial, I figure if it is eroding quickly, it is doing so to protect the system. Since they are cheap and easy to replace I buy several at a time and replace when they drop below 50-25% of original mass. Some water requires the aluminum anode if the magnesium anode goes away in a couple of months or less.
Interestingly, earlier in the week, while parked at Sesquicentennial State Park in Columbia SC, the water started smelling like sulpher, I thought 'oh no', and planned a flush and decontamination of the water system. But after leaving and travelling to a park in TN, the sulpher smell is gone, it was part of the chemical makeup in the Park's water supply. I imagine that would wipe out an anode in a short time.
anode, fr3
