Old 05-13-2015, 05:48 PM   #1
2015 FR3
JEGNCJG's Avatar
Anyone know where to get a tire valve extender that will fit the rear outside tire on
Anyone know where to get a tire valve extender that will fit the rear tire on the 30DS? I've tried
JEGNCJG is offline   Reply With Quote
Old 05-13-2015, 05:49 PM   #2
2015 FR3
JEGNCJG's Avatar
I've tried all that my dealer has and none will work.
Old 05-13-2015, 08:25 PM   #3
leisurelarry's Avatar
I use 135 degrees "Wheel Master" valve extenders on my outside rear tires. Fit perfect! Should be able to get most places.Click image for larger version
Name:	ImageUploadedByForest River Forums1431566690.783711.jpg
ID:	76886Click image for larger version
Name:	ImageUploadedByForest River Forums1431566709.081666.jpg
leisurelarry is offline   Reply With Quote
Old 05-13-2015, 10:04 PM   #4
Ditto on 135 degree wheel master. Just installed them and got them off of Amazon.
KansasFR3 is offline   Reply With Quote
Old 05-14-2015, 12:07 AM   #5
fdp
The problem is that the air will not push thru two valves very well
fdp is offline   Reply With Quote
Old 05-14-2015, 07:59 AM   #6
My dealer installed extenders on the rear valves (they should be standard equipment - are you listening FR?). The 135s they're referring to above wouldn't work for me as I have a tire pressure monitoring system with sensors that are large and fit on the end of the valves.
Jay & Jane
2014 FR3 30DS
FL & MN
Live Aloha
spicyrv is offline   Reply With Quote
Old 05-14-2015, 11:48 AM   #7
I use TST TPM and I use 180 degree extenders. They work pretty good.
oakprk is offline   Reply With Quote
Old 05-14-2015, 11:49 AM   #8
try camping world
wire1946 is offline   Reply With Quote
Old 05-14-2015, 12:13 PM   #9
Tinbender1947's Avatar
Mr
Duallyvalve Kits for Class B or C - Sprinter Trucks
Try here, great company to deal with and can contact by phone if you need to.
Tinbender1947 is offline   Reply With Quote
Old 05-14-2015, 12:15 PM   #10
I had the same problem with my 2011 Georgetown 327. I used the 135 degree extender then added another straight one to bring it out beyond the hubcap. I have no problems filling the tire using a clip-on connector that locks to the valve stem.
Phil
pmsherman is offline   Reply With Quote
tire
