10-26-2016, 05:12 PM
#21
Left Coast
Want the cans back?
10-26-2016, 06:02 PM
#22
guess not
Na. I'll just cut my lip lick'en the hole where the beer comes out... dang that alumimimiuninum is sharp..
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
10-26-2016, 06:28 PM
#23
Originally Posted by Ford Idaho
We keep a small one in the FW, it's good for taking the chill off during a cool morning or a rainy day.
Rides under the bench seat of the dinette.
Ditto for us...
10-26-2016, 06:34 PM
#24
We heat our 5er with an Eden Pure. Added a separate circuit for it. Can move it over by the furnace and just turn furnace blower on and it circulates the air all thru the underbelly and the 5er.
10-26-2016, 06:39 PM
#25
My trailer came with two electric fireplaces. They heat it very nicely. Each has it's own built in thermostat and dedicated breaker (50A service). We usually leave the one in the living room on at night and turn off the one in the bedroom. On really cold nights, the one fireplace cannot keep up so the furnace will cycle to maintain a minimum temperature. I installed a programmable thermostat on the furnace so the trailer heats up in the morning before we get up.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
10-26-2016, 07:06 PM
#26
my 5er also came with a electric fireplace- here in upstate ny I use it in my house during winter, I have to remove it anyways to get to the water filter which is behind the fp
2009 gmc sierra 3500 diesel dually slt
2015 8528rkws -solor panel-slide toppers-jt strong arms
10-26-2016, 07:18 PM
#27
Originally Posted by SidecarFlip
Don't get that. We use an electric blanket all the time. One with 'his' and 'her' controls...
That is the best news ever!!!!
10-27-2016, 01:08 PM
#28
Originally Posted by Mtelkman
I never thought about using one of those but if you have the room I don't see why it wouldn't work. We just use $15 Walmart 1500watt ceramic electric heaters when we are at a campground with hookups. I highly doubt that any heater you find that plugs into a standard plug will put out more than 1500watts no matter the size. But that electric fireplace might be more visually appealing if you have the room for it.
X2 We use a 1000 watt space heater that oscillates. Stores under the sofa and keeps the chill off the living area on those cool nights. Works perfect because we like our bedroom cool.
10-27-2016, 01:23 PM
#29
Originally Posted by KevandSyl
That picture makes the little fireplace look bigger than it is. It is 16 x 11 x 21 with adjustable 750w/1500w. It is only 79 bucks from Plow and Hearth and I thought - aww so cute. Then I saw a warning on my electric blanket not to use in a RV. That scared me. We are newbies - your expertise is soooo appreciated!
Compact Electric Stove | Electric Fireplaces | Plow & Hearth
Don't understand that warning. My FIL has been using an electric blanket in his Class C for years. And Roo's/Shamrock's have heated mattresses (located essentially in a "tent!").
2011 Traverse LT, 3.6L, FWD
10-27-2016, 01:25 PM
#30
I've used an electric blanket in my RV for years. (actually heated mattress pad)
Not sure why the warning?
If you like the cute fireplace, go for it.
You shouldn't have any problems whatsoever, especially on low. (750w)
10-27-2016, 01:32 PM
#31
Left Coast
10-27-2016, 01:37 PM
#32
This electric blanket warning intrigued me, so I Googled "Why no electric blanket in an RV??" About the only negative thing I could find was that some blankets apparently don't play well with some cheap inverters or lousy generators that don't put out a nice sine wave.
If that's really the reason, then the blanket should have warned not to use with lousy generators or cheap inverters that don't put out good sine waves; it should NOT have simply said not to use in RV's. But I guess it's a CYA world we live in.
10-29-2016, 08:40 AM
#33
http://www.plowhearth.com/compact-electric-stove.htm
I have several retired fire fighter friends. Not 1 would ever use an electric blanket other than a warm up on a cold day and then unplug it. They all have responded to emergency calls where people were badly burned.
People complain about China bomb tires......who is making these blankets?! Think about it.
10-29-2016, 09:15 AM
#34
Originally Posted by bob caldwell
You got big brass ones to install a pellet stove and a double wall flue and all in that tinder box they call a trailer. I would have to be vigilant on using it, let alone if any sparks hit the roof from the flue..Stay safe Bob, your the first that I know of ever...
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2016, 09:19 AM
#35
LOL. If you've seen it on the Internet, it must be true!
Or not.
10-29-2016, 01:02 PM
#36
Left Coast
X2......lol
11-09-2016, 08:48 PM
#37
Rickydeee
Portable heater fireplace
Here's a good price on a 750/1500W model with fan. Switch to 750W setting when using other high-load appliances or electric water heater.
https://www.walmart.com/ip/Electric-...hod=p13n#about
11-09-2016, 10:01 PM
#38
Some electric blankets are not compatible with power inverters. I power my tv's with a power inverter and we hadn't unplugged the electric blankets. They were both turned off, but both controls were smoked. I had to open windows to clear all the smoke. Since many RVs have power inverters, they tell you not to use these blankets. I'm getting a new inverter that is "pure" or "true" sine wave instead of the common, "modified sine wave" inverters. This should eliminate the risk, should we forget to unplug them.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
